fuel reserve when needle low...
Old May 30, 2004 | 04:51 AM
RX8zoomDW's Avatar
Smile fuel reserve when needle low...
Could someone tell me about how much fuel remains when the needle hits the E? I'm just trying to get grips on my full mpg. Thanx.
Old May 30, 2004 | 06:25 AM
rxeightr's Avatar
M0D Squad -charter member
Not to be confused with the low level light, I have ~ 15 miles of gas left when the needle is on E.
Old May 30, 2004 | 01:46 PM
mfreilly's Avatar
I figured about 3 gallons when the light comes on, just under two as the needle approached "E".
Old May 30, 2004 | 07:04 PM
r0tor's Avatar
Re: fuel reserve when needle low...
don't use the needle position to figure out your mpg... figure out your gas milage when you fill up and know exactly how much fuel you used.
Old May 30, 2004 | 08:28 PM
rx8daniel's Avatar
when the light goes on, you have used about 13 gallons; when you hit "E" you have maybe 1/2 useable fuel left. You will have a difficult time using the 'entire' tank capacity [impossible, really]. search for my earlier posts about running out[last Aug time frame]
Old May 30, 2004 | 10:46 PM
w2aew's Avatar
www.dorkage.com
Like PrOber said, figure your mileage correctly by dividing travelled miles by the gallons to fill. Gauge position will vary, and will NOT give you an accurate MPG measurement.
Old Jun 1, 2004 | 09:01 AM
HollywoodHall's Avatar
so the question of the day is... exactly how far can your needle go below e for us dangerous drivers.... like how much gas is left in the car when the low gas light first comes on.. anyone know?
Old Jun 1, 2004 | 12:59 PM
zoom44's Avatar
just read the posts suggested by rx8daniel
Old Jun 2, 2004 | 08:28 AM
im looking for exact. the tank holds what 15 gallons.? I know that when i fill up the light is on. and i can typically put about 13.-13.5 gallons in it to reach max capacity. just trying to see how far i could push the gas in my car without having to call mazda roadside to come bring me gas on the side of the road. lol
Old Jun 2, 2004 | 01:30 PM
rxeightr's Avatar
This morning I filled up with my needed (1) needle width below the E.
Took 14.1 gallons - for 310 miles driven.
Hope this helps. I have not gone below that on my gauge, however I have gone this far on several occasions.
Old Jun 2, 2004 | 02:01 PM
RX8Mongoose's Avatar
was this a typo? 310 miles? 22mpg?
i'd like to see 22 mpg
Old Jun 2, 2004 | 04:18 PM
rxeightr's Avatar
No typo
Old Jun 2, 2004 | 04:46 PM
wangdda's Avatar
this reminds me of that one sinfeld episode
Old Jun 4, 2004 | 10:01 PM
TRZ750's Avatar
320 miles, WAY below the "E" and took 14.6. Once earlier when I didn't know where a statuion was on a trip I took 15.2 gallons. Every car I have had I like to slowly run it further down. Next time I will bring a gallon with me and run it out. That way I will really know when I get caught in a strange area again.
Probably each car is slightly different on the gauge reading. Also, as others have said, the take has two parts and some gas can slosh ofer to the other side when turning or on a rough road, so be carefull when you work it down.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
