Chewed up 1st gear?
Old May 28, 2004 | 08:50 PM
Tony_Montana's Avatar
Chewed up 1st gear?
Ive heard this phrased used alot on the forums, and i think it means you chew up your gears in 1st gear that makes it non-driveable. If iam right dose this mean the transmission isnt really good for high rpm clutch drops? Just wondeirng....
Old May 29, 2004 | 11:10 AM
epitrochoid's Avatar
Riot Controller
dont be road and track and do 8k clutch dumps...bad bad idea
but yea, first gear just..breaks and cant be used. i believe reverse goes out with it
Old May 29, 2004 | 04:35 PM
what is a " safe " rpm to drop the clutch, i read somewhere between 6-7k is your maximun limit.
Old May 29, 2004 | 06:21 PM
mysql101's Avatar
I don't know ... since I plan on keeping my car, I have only done one clutch drop from around 6000 rpm. Since then it's all smooth driving.
Old May 29, 2004 | 06:33 PM
guy321's Avatar
Humpin legs and takin nam
I've done 6k at the most and got severe wheel hop that I didnt like..
I also just had my tranny rebuilt.. but that's totally unrelated.
Old May 29, 2004 | 09:49 PM
red_rx8_red_int's Avatar
Are you sure it's unrelated?
Old May 29, 2004 | 09:54 PM
guy321's Avatar
Positive, it did it long before I took it to the track.. I just really didn't realize it was a problem.. then other people started mentioning the same prob.. It's pretty common for earlier cars even tho there's no TSB.. shift fork problems.
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
