Spring rates
Old May 9, 2004 | 11:28 PM
Skinny's Avatar
Spring rates
OK guys need a little help! Does anybody know the factory spring rates? I'm considering a couple different spring packages but I'm having a hard time finding info. I like the tein springs, but not sure what the difference is between the s-tech and the h-tech (rates)? I was also considering the tanabe springs. Would also need help the alignment specs also. Thanks for the help in advance.
Old May 10, 2004 | 09:51 PM
Kel Rx8's Avatar
if your not 1st your last
i have the tein s and i feel like a 100% satisfied.
i seen the tanabe installed on a 8 before it was dunked way too low and uneven his rear was even lower than the front.(but i think he might of cut a coil or so.)
as for stock springs have a horrible weight rate.well maybe the stocks my car came with cause as soon as anyone got in my car it would lower alot.
Old May 14, 2004 | 08:40 PM
Skinny's Avatar
I was curious if I go and get my alignment settings before I change my springs, can I use those settings afterwards? Thanks for the info Kel
Old May 15, 2004 | 10:38 AM
Kel Rx8's Avatar
n/p
get the springs 1st
put them on see if you need a alignment 90% of the time you
what springs are you thinking of getting ?
Old May 15, 2004 | 01:58 PM
Skinny's Avatar
I'm trying to find out what the difference is between the s-tech and the h-tech. I want to drop an inch or so but not overly increase the spring rate. I have read that you are running 20's. I am getting ready to order a set of 20's but I havent taken the measurements yet. If you can give me the numbers it would be great. Did you need an alignment afterwards?
Old May 15, 2004 | 11:53 PM
Kel Rx8's Avatar
no problem
p/m me with questions and such
we can conv. there.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
