OFFSET help!
Old Apr 30, 2004 | 08:54 PM
R888's Avatar
WedsSport Member
Question OFFSET help!
Already being patient for 3 weeks and still another 4 weeks to go for my Titanium RX8 arrival. I have been reading a lot of posts. Regarding to the offset there is lack of information on this topic. Although I knew the front is 18x8 for the factory rims but what about the rear?
I finally decided to put VOLK RACING GT-U GUN METAL to fit my Rx8 but my question is what will be the best offset to put? like 18x8 and 18x9. Although I know the OFFSET for 19 is 19x8.5 19x9.5. My guess is 18x8 and 18x9 will be prefect? Correct me if I am wrong.
Thanks for your help in advance!!
Old May 1, 2004 | 09:15 AM
Offset is the position of the mounting face in relation to the wheels outer surfaces. It is a # like 30, 35 etc. in mm. Will change with wheel width ie 8 or 8.5 or 9....to allow the wheel to be in the correct position so that it doesn't rub
Old May 1, 2004 | 10:38 AM
Gord96BRG's Avatar
You should be posting this in the Tires and Wheels section, but as mentioned by dannobre, you're not talking about offset, you're talking wheel width. I think you need to spend a few minutes reading the articles in the www.tirerack.com tech section to learn about offset and width.
Stock offset on the RX-8 wheels is 50mm. The RX-8 is designed for nearly balanced handling with the same width wheels and tires front and rear (nearly balanced - it does understeer at the limit). If you put wider wheels and tires on the back of the car, you will just make the car understeer worse - that would be bad. Unless you compensate by installing different shocks, springs, and sway bars designed for neutral handling with a staggered wheel/tire combination, you will be making your car handle worse.
Regards,
Gordon
hufflepuff
May 30, 2016 10:45 AM
Richard Paul
Aug 17, 2015 01:49 PM
R2D2X8
Aug 17, 2015 08:47 AM
jaehyun127
May 29, 2004 08:04 AM
