Hard Shifting after 1500 miles.
Old Apr 21, 2004 | 05:31 PM
Everett's Avatar
Hi all:
I am new to the Forum. I have 1500 miles on my 8. When purchased the shifting was smooth on all gears except 1st, which I understand why, since the same thing happened on my 2000 S2000.
For the last 100 miles, I have been getting intermitent hard to engage shifts, specially third gear. Even if I use the recommended low RPM shift points.
Has anyone had this problem? I have taken care of my car since the beginning without abusing it, so I dont know what can be wrong with it.
Any reccomendations or solutions?
Thanks,
Everett
Old Apr 21, 2004 | 11:05 PM
wakeech's Avatar
mostly harmless
it's not clear what the symptom is.
what is "intermitent hard" to engage the selector??
Old Apr 21, 2004 | 11:18 PM
Everett's Avatar
My apologies for not being so clear.
Yes, sometimes when I shift the engagement in the selector is hard, even thou I have the clutch pedal fully pressed.
Thanks,
Everett
Old Apr 22, 2004 | 03:19 AM
Rotary Titus's Avatar
change your tranmission/diff fluids
I had that same problem (mine was hard to engage 2nd, 3rd and reverse) but after the fluid change it was bolt action smooth again!
though maybe different for your case, just a suggestion if worse comes to worse and nothing helps!
Old Apr 22, 2004 | 11:32 PM
kbull's Avatar
Senior Jackass
Now that you mention it, I've had a little trouble getting it into 3rd. I thought it was just my poor shifting, but every now and then I'll try to get it into third and the gearbox denies me. Thought I just wasn't pushing hard enough. Maybe I'll take it to the dealer and demand a fluid change, then they can give me the M flash I've been wanting so badly....
Old Apr 22, 2004 | 11:50 PM
Everett's Avatar
Hi K Bull!!
Keep me updated if the tranny oil change works.
Do the M Flash! It's like driving a new car!! Je,je!
Cya!
Everett
Old Apr 23, 2004 | 09:57 PM
Everett's Avatar
Hey Guys!
Quick update! Called today a friend in the Mazda Distributor here in Puerto Rico. I explained the situation. He told me that they have seen that before, and it is solved by tightening the pressure plate bolts.
I have an appointment 8:30am on Monday. Will keep you updated.
C ya!
Everett
Old Apr 23, 2004 | 11:05 PM
kbull's Avatar
Senior Jackass
Well, thanks, Everett. Good to know. I suppose I'll be going in next week for that very issue (and the M flash, of course )
Old Apr 24, 2004 | 11:47 AM
spdspappy's Avatar
You may also want to put Royal Purple Synthetic in your tran. & diff. It's made a big difference...
Old Apr 24, 2004 | 12:24 PM
Gyro's Avatar
Rotary Abuser
Just wait until you get it back....it will feel great once the pressure plate bolts are tight.
My bolts loosened up a few weeks ago also.
Also...the job only requires the removal of the starter.
My tech told me the torque spec for the bolts is onlt around 20 lbs. He added locktite to each bolt just to make sure.
Old Apr 26, 2004 | 03:57 PM
Everett's Avatar
Hello Guys!!
To update you, I picked up my car today from the Dealership.
Pressure plate bolts tightened. My transmission feels silky smooth.
Everything is working great kwno, better than in day one.
I will change the trany and differential fluid this weekend.
Thank you all for your guidance.
Regards,
Everett
Old May 4, 2004 | 10:48 AM
TuscaniV23's Avatar
Hi All:
Quick update!
My trans is getting hard to shift again. This sucks!!
Called my Rep. They order a new transmission. They will replace upon arrival.
Any chance this can be anything else other than the trans?
Thanks,
Everett
Old May 4, 2004 | 10:54 AM
Everett's Avatar
Hi All:
Quick update!
Thanks,
Everett
theblinkof
Oct 4, 2023 05:24 PM
crimson809
Aug 14, 2016 10:03 PM
JCTaylor
Sep 30, 2015 07:31 PM
XianUnix
Sep 29, 2015 03:48 PM
