Drive Train
Old Apr 3, 2004 | 10:20 AM
Xwingnut's Avatar
Question Drive Train
I am new to this site, own a 2004 RX8 4 speed auto. My question is: Does the limited slip differential make noise when first engageing the transmission in drive or reverse?
Mine does, when I put the trans in D or R as the car starts to roll I hear a noise that sounds like its coming from the differential or possible the trans.
Anyone with an auto have the same?
Xwingnut
Old Apr 3, 2004 | 12:00 PM
sferrett's Avatar
Whaaaa?
It's probably the ABS doing a self check - it should only happen the first time after starting the car when you go over 1 or 2 mph.
If this noise is happening everytime you start from a stop, it could be something else.
Old Apr 3, 2004 | 08:54 PM
Xwingnut's Avatar
sferret, that is exactly when it happens, on first roll off at 1 to 2 mph.
Thank You, mistery solved, now I won't be bugged about it.
Xwingnut
wayloco
Sep 1, 2015 09:03 PM
Klaudio prela
Aug 26, 2015 02:58 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
