L-reflash G-tech results
Old Apr 3, 2004 | 08:39 AM
OverLOAD's Avatar
Hyper Space RX-8 _,.-^'`
I got my RX-8 reflashed with the infamous L reflash.. here's there G-tech results.
Runs # 0 & 1 were from November 2003, and were some of my best runs to date.
Runs # 2 & 3 are with the L-reflash. It's definately faster, however my lack of intimacy with my RX-8 over it's garaged winter has reduced my quickness and made my shift points much less reliable. I plan to get out there again next week and try some more to see what can be done about it.
Definitely, I've noticed that there is a bigger rush of power around 4500 to 6000 rpm, but at the same time, the power above 7500 rpm has deminished..
Reagrds,
OverLOAD
Old Apr 3, 2004 | 08:46 AM
Speed-ER doc's Avatar
yes, I bite
Your 0-60 and 1/4 mile averages are slower with the L reflash.....
Old Apr 3, 2004 | 09:21 AM
OverLOAD's Avatar
And my driving was worse too. I think that the L reflash is faster, if you drive the exact same way, unless you spend all your time above 7500 rpm...
OverLOAD
Old Apr 3, 2004 | 10:51 AM
wakeech's Avatar
mostly harmless
i think what we need here as a sort of real guage of how the flash has affected the car is a comparison of long gear pulls (like 1500 - 9000 in 2nd gear) where you're not shifting at all, taking driving skill and conditions out of it entirely. as long as it's along the same road (to account for immesurable slope) you'll get more comparable results (noting things like tempurature and humidity, gasoline used, stuff like that).
Old Apr 3, 2004 | 05:14 PM
r0tor's Avatar
run 4's hp is probably down because the results look like they are comming from 3rd gear rather then 2nd so there is more wind resistance
Old Apr 3, 2004 | 05:42 PM
rotarygod's Avatar
Now that is a damn good idea! It could even be done with a stopwatch. To take stopwatch user reaction error out of it I'd do it in a higher gear so it takes longer. If there is a gain it will still show up as a quicker time regardless of gear.
Old Apr 3, 2004 | 05:59 PM
r0tor's Avatar
i've been begging someone to do this (especially for the CZ mod) for months now....
Old Apr 3, 2004 | 07:33 PM
TM45's Avatar
I tested 0-60 after the L flash with my g-tech and it was four tenths slower. In every day driving it seems more responsive, but the pull at high revs is weaker. After the flash it was quicker at the start but took 2 seconds to go from 50-60. Before it was slooow to get going but closed with a rush.
Overall I am happy with the L flash. I am too old to race and the car now feels faster in normal driving situations.
Old Apr 3, 2004 | 08:30 PM
Rotarian_SC's Avatar
Free Autographed Pictures
Your trap speeds seem better, but your 60' times have gone down a little, maybe it is the lack of launching practice. So you sacrifice top range for midrange. I think it would be interesting to compare dynos, like take it before you go to the dealership, and then take it after you have come back from the dealership. One thing I am interested about is the HP/Time curve, to see if L makes it rev faster. I can' really tell much from the tiny little graph i can see
Old Apr 3, 2004 | 09:22 PM
TurboRX8Girl's Avatar
First tank on the L flash with my auto, and I just got 22 mpg.
Before I attribute it to the L flash, I also filled up with 87 for the first time. With 4K on the car, I have always used 91, but tried the 87 just before the flash on a half tank. Hard to say what made the difference, but I have always got around 18 - 20 MPG.
This is the best MPG to date for my car.
I have tested the first gen G-tech before the L flash and netted 122 hp on below 80mph on three runs (the only runs). I will test the car soon with the L flash.
Old Apr 4, 2004 | 03:07 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
This iswhat I was afraid was happening w/theL reflash. I dont think I want it anymore. I prefer a delay andthen a rush over a rush and then a delay.
Old Apr 4, 2004 | 08:01 AM
adrian-1's Avatar
Ex- member.
Had my G-tech ready for months to do this! Just waiting on Canzoomer to deliver the final version.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
poacherinthezoo
Aug 3, 2016 11:01 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
rxwilly8
Sep 2, 2015 02:42 PM
