durrada
03-29-2004, 05:16 PM
This weekend I experienced an electrical problem with my RX-8. While driving, I pressed the "up arrow button" on the steering wheel in order to go to the next song on a CD. After pressing this button, which I have pressed many times before, the stereo and most accessories in the car immediately turned off. Me, being the rocket scientist that I am, decided to pull over, turn the car off and check it out - can you say stupid, drive home first !!
So, here's what had happened. The car blew the 30A ACC fuse under the hood in the fuse box. Cool, hey. Not too weird for a car, though, this happens. However, I didn't have any of those types of fuses as extras. While I don't expect this to be a recurring problem for ev1, I suggest ev1 stop by their local auto store and get a couple of these fuse types for their trunk :)
To make things even worse, some moron engineer at Mazda decided to wire the ignition into the ACC fuse. Brilliant !! So, if you overload your accessories for whatever reason and you stop the car, guess what, you can't start it !!!! There's a braniac for ya. Sure would hate to wire the ignition to the Ignition fuse - lol.
Anyhoo, long story really long. I managed to jerry rig it, get to an auto store and replace the fuse. The next day I went through 3 30A fuses trying to get it restarted again. The car is now at the dealer as they search for the short - that should be interesting - the blind leading the clueless. That's probably not fair, but will more than likely end up true - lol.
Just thought I'd share this wonderful info with you all. If you wish to test the starting information. Just pull the 30A ACC fuse from your box and try and start the car. Brilliance at work :)
David
P.S. - Once I find out what the problem was, I'll post it.
David
