Stock RX8 vs. Modded RX8
Old Mar 27, 2004 | 08:34 PM
paradigm's Avatar
Seen Your Member
Before you ask my mods are in my sig......
And yes, I know street racing posts are not allowed on this forum, so I don't know how long this'll be here. Moderators, forgive me, but there really isn't anywhere else to post this and I figure people might want to know.
2 runs......roll on @ 20mph in 1st gear. Both cars are manuals.
Run #1: My car wins by a gap of over 2 1/2 car lengths before the end of 3rd gear. Saw him in both mirrors. *edited to make Ike happy*
Run #2: This one was supprising at first. The stock 8 hung with me through 3rd gear. Stayed at my door the whole time.
So what do we learn from all of this? *edit* My foot tastes like chicken.
One of these days I'll take a few days off work to run it at moroso and post some timeslips.
Old Mar 27, 2004 | 08:56 PM
amartin's Avatar
What is it you think you did to gain 30-40hp (Rear-Wheel!?) to your RX-8? Or should I say, to go from 238->280 HP?
... I'm going to have to pull up the 'clueless/BS' flag on this one.
Old Mar 27, 2004 | 09:04 PM
paradigm's Avatar
Seen Your Member
The mods I have are stated by their manufacturers to give about 10hp each. Manufacturer's claims are mostly BS. I can doctor a dyno run just as well as they can. When I dynoed my car with intake, midpipe, and catback I only put down 170 to the ground. Same as what a stock 8 put down on the same dyno I tested on. But, the gap between my car and the stock 8 would be consistent with an aproximate 30hp gain over stock.
*edit* and I'm certainly NOT clueless.
Old Mar 28, 2004 | 01:02 AM
Ike's Avatar
Ike
Blue By You
Actually what your run indicates is a drivers race, in the first run you drove better than him and maybe got a little bit of an advantage from the mods. The second run was more realistic since you probably have minimal HP over stock with your mods. You're probably lucky if you're not losing HP from your intake, and you biggest gains are from the removed cats. Which are probably about the gains that you would get from having a stronger car from the factory over a weaker car from the factory. You can talk about heatsoak when you get a turbo...
Old Mar 28, 2004 | 01:55 AM
paradigm's Avatar
Seen Your Member
He probably had the advantage in the driving department, since his tranny is still in good shape and mine...well......isn't, after the incident I had a while back. Besides that, there's not a whole lot of skill in racing from a roll.
And you may be right about the mods. Hell, my dyno pulls say you ARE, but my experiences show me there's a little bit more power there somewhere. But since my experience doesn't equate to a nice power graph, I'll concede the point to you.
As far as knowing what heat soak is and getting a turbo............no thanks. Been there, done that. A 70 mile daily commute in an rx7 is not fun in florida.
I'll find another stock 8 to run, just in case he got a bad one from the factory. I'm gonna try to find someone with the CZ stage one, or other fuel tuning computer to see how that goes as well. Believe me, I'm not just saying "hey I won twice, that means my car is a lot faster than a stock 8." This was just my experience today. Take my post for what it's worth, which is just a little experiment, and the results.
Old Mar 28, 2004 | 02:02 AM
amartin's Avatar
Well, all I have to say...is if you can get >40< HP from those few mods... my hat is off to you.
Now, back on earth... there's no way.. of, and FWIW, I have the stage-1 mod on my RX-8 and its still no where close to the performance of my S2000 (well..its "close", but won't win from any speed). So, don't count on the Stage-1 giving u a ton of power.
Now..back to math.. lets say u got 40hp..thats about 16% increase in HP.. highly unlikely for N/A. Now, lets also consider..if you had ~278 HP, you would most likely destroy any RX-8 from any speed (as he would be in the same gear, assuming similar drivers, similar start times, etc.)
I think its realistic to assume your not getting the +30 to +40 hp the manif's claim :-( If it were true, however, I'd be right behind you getting those mods.
-- Aaron
Old Mar 28, 2004 | 04:45 AM
Ike's Avatar
Ike
Blue By You
You'd be amazed how many people bounce of the rev limiter, miss a shift, or shift too early, or just start in the wrong gear when racing. Not a lot of skill involved in racing from a roll, I agree, but that doesn't keep a lot of people from screwing it up :p
Old Mar 28, 2004 | 11:10 AM
amartin's Avatar
Start from 10mph in 3rd or 4th (10mph might be a tad too low for 4th)... And just 3 honks and WOT... takes a lot of the 'driver error' out of it, though its a lot more boring for the first 20-40 seconds :-)
..but seriously, thats probably a better way to compare two RX-8's instead of banging gears.
-- Aaron
Old Mar 28, 2004 | 11:27 AM
paradigm's Avatar
Seen Your Member
good idea. I'll give it a shot next weekend.
Old Mar 28, 2004 | 12:23 PM
Astor's Avatar
They Come At Night
If I were rolling at 10mph, I would still be in 1st, then shift between 8,500 & 9k, keep it in the upper range and the peak of your torque.
Old Mar 28, 2004 | 08:47 PM
amartin's Avatar
If he wants to compare appls to appls... the idea was to eliminate a lot of the driver error (ie. shift points, miss or slow shifts, shifting at different rpms, etc..).. hence the suggestion to start from 3rd at 10mph.
-- Aaron
Old Mar 29, 2004 | 01:52 PM
GeorgeH's Avatar
I'd recommend a roll-on from second, if you want to account for the effect of the flywheel. The effectiveness of a lightened flywheel is directly proportional to the angular acceleration of the crankshaft - in other words, you'll notice it most in first, less in second, and in third it might be imperceptible. That's how it worked out in my Miata.
So, a second gear run from 1500 rpm to redline would work well if you want to account for the flywheel but eliminate shifting errors.
Old Apr 1, 2004 | 06:02 PM
NAVILESRX8's Avatar
FWD Hater
I love it when people add up all the horsepower claims each mod gives......
It doesn't work that way....
Old Apr 2, 2004 | 10:49 AM
what are you talking about? i have 10hp from intake..12hp from exhaust, and 6hp from flywheel..i have almost 50 hp..hahah
Old Apr 2, 2004 | 11:15 AM
Lawerence's Avatar
You guys know about the law of diminishing returns right?
I hope so...
michaelsk8er
Nov 9, 2015 07:06 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
RX7.9
Jul 20, 2015 12:01 PM
