MS front bumper install impressions
Old Mar 22, 2004 | 01:16 PM
PUR NRG's Avatar
Installed the MS front bumper yesterday. Overall the process went much quicker and easier than the rear wing or side skirts since no drilling was involved.
Suggestions:
1. If you're replacing the front bumper, it's a great time to change to clear side lights as well.
2. There is a locking tab just in front of the side marker lights. Pull the sides away far enough and they will pop out.
3. Unless you have a black car, the metal bumper may be visible below the center grill's top plastic strip. If that's the case use flat black paint.
4. When installing, hook bumper on center retaining pin first. Then push bumper under the headlights and lock the rearmost slot over the side marker tab. Make sure the locking tab mentioned previously is under the body panel above it and give it one sharp pound with your fist to lock it in place.
Observations:
1. The MS front bumper has a grill to keep debris away from the water radiator. On the stock bumper the bottom inlet doesn't have any protection. In theory it's possible a plastic bag could get sucked into that opening and due to the car's design, there's no place for it to exit. It will remain trapped covering part of the radiator.
2. The MS front bumper on stock springs sits 5.25" above ground. The MS side skirts sit 5" above ground. This barely clears the guide rail at my local car wash. Once the JIC coilovers are installed I'll have to wash to car by hand only.
________
NO2 VAPORIZER REVIEWS
Old Mar 22, 2004 | 01:25 PM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
You were sending your 8 through an automatic car wash
Old Mar 22, 2004 | 01:32 PM
PUR NRG's Avatar
Sort of. It's a hand wash with automatic rinsing. Perfectly safe for your car's finish.
________
Mercedes-Benz C-Class History
Old Mar 22, 2004 | 01:56 PM
mikeb's Avatar
100% Italian
feel like posting pictures???
Old Mar 22, 2004 | 02:02 PM
PUR NRG's Avatar
Is there anything I can post that hasn't already been seen before? I've already posted pictures of the Pikachu graphic. The complete MS body kit has been posted multiple times. The JIC coilovers have been featured as well. Perhaps the only thing I have on order that hasn't been posted is the RB exhaust.
I'd like to wait until all the parts are installed (mid-April, honest!) before posting pictures. But if there's enough interest I can post some interim pictures before then.
________
No2 Vaporizer
Old Mar 22, 2004 | 02:12 PM
mikeb's Avatar
100% Italian
you are right
but It sounded like you did some custom work to the ms front
Old Mar 22, 2004 | 02:50 PM
PUR NRG's Avatar
The only custom work was a passenger-side air duct for the oil cooler. It's a neat bit of work but totally unimpressive to look at. And if Mazda actually makes it for sale in the US, it's (almost) a wasted effort.
________
IPAD GUIDE
Old Mar 22, 2004 | 05:21 PM
r0tor's Avatar
one more tip - don't forget to disconnect the fog lamps before trying to remove the front bumper .... not that I just forgot to do that this weekend :o
Old Jan 12, 2012 | 04:38 AM
Thoroughscrub's Avatar
Rollin' 7s
I took my truck to a car wash once. I ended up with 2 huge (though shallow) scratches and an 8 inch dent.
Never again. I always wash my cars by hand. 5gal bucket, some good car soap, a microfiber mitt, and one big microfiber drying towel.
Ya get to be intimate with your car, and the shine is twice as nice, and rx8 times more satisfying.
Old Jan 16, 2012 | 06:50 AM
limpbozkit's Avatar
Gets the WORST mpg
Whoa THREAD RESURRECTION!
Old Jan 16, 2012 | 09:47 AM
dmedz8's Avatar
Needs Boost!
8 years.... Impressive.
Old Jan 17, 2012 | 02:29 AM
Rollin' 7s
limpbozkit, you have 138 posts. Reading that, I thought it said 13B. :D
Old Jan 18, 2012 | 02:35 AM
limpbozkit's Avatar
Gets the WORST mpg
Ha ha ha ha. Well I guess you can't make mistake anymore now.
Old Jan 19, 2012 | 03:02 AM
Rollin' 7s
Sadly..
Old Jan 19, 2012 | 11:24 PM
monchie's Avatar
I HATE SPEEDBUMPS!
For the last 8 years and revisiting this thread and opening it again is obnoxious.
Old Jan 19, 2012 | 11:37 PM
limpbozkit's Avatar
Gets the WORST mpg
Reading your posts is also but neither can be changed.
Old Jan 20, 2012 | 02:46 AM
Rollin' 7s
^ Yeah... I'm not sure what he's trying to say.
So don't open it, because the two clicks it takes to unsubscribe has to be less obnoxious than all this now.
MsKingRotary
Jan 28, 2016 12:12 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
TheRedRotor
Aug 9, 2015 11:23 PM
