Best way to jack the car?
Old Mar 21, 2004 | 06:58 AM
flatso's Avatar
I'm Tantalizing
What is the best way to jack the car so that you get all 4 wheels are off the ground? Ramps are great but not for doing things like rotating tires. So what is the best way to jack up the front and rear? I've heard pro's and con's about using the diff to jack the rear of the car and not sure about the front.
And what is the best way to tell if the car is jacked up level to do things like change tranny fluilds and diff fluids?
Old Mar 21, 2004 | 11:45 AM
Chris in MD's Avatar
I was going to give it my first try to jack the car today - found a thread that talked about using jack points along the "rail" (frame) that runs between the front/rear wheel wells. Also some other points that some members preferred instead. If using jack stands and a floor jack however, I would need four points to get two wheels off the ground on the same side.
Jack Point Thread
Old Mar 21, 2004 | 12:20 PM
flatso's Avatar
I'm Tantalizing
ya saw that thread but still wonder if there is something in the center because if you use those jackpoints you have to lift one side but how do you get the jack under the side your lifting.
Old Mar 21, 2004 | 12:47 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
I haven't seen it done with an RX8 yet, but Miata guys would often fit their floor jacks with a grooved 2x4 that fit the frame rail lip and offered enough weight distribution to lift the side up in the center using one jack point.
Personally, I never wanted to risk it (collapsing the frame rail lip and possibly bending the rail), so I bought a cheap set of jack stands and a small floor jack ($20 or $30 for all of it), and use all four jackpoints with jackstands. The floor jack will lift the side in just a few pumps, so I can have the car up in the air within 2 minutes or so. This is great for rotating tires, changing oil/fluids, or just looking at how Mazda put the thing together.
Old Mar 21, 2004 | 02:59 PM
XcelR8's Avatar
When in doubt XcelR8!!!!!
When I did the caliper painting over a weekend I lifted the car by each of the jack points. I did the rear first and it lifted enough to put a jack stand under the front A arm also. I put a stand under the back supension arm. Then lifted the front to adjust the jack stand higher to get the tire off. My concern was too much lean angle on one stand. It was solid when in the air. Not sure where I will put the jack stand when I install my springs, thats going to be a bitch.
Old Mar 21, 2004 | 03:38 PM
Baller's Avatar
Chicks dig me!
The best way to jack a car here is with a gun, of course....
Old Mar 21, 2004 | 07:46 PM
Used my small floor jack to jack the rear - one at a time. Wanted to put some treatment on the surface rust on the wheel hubs (only seemed to be on the rear wheels) - looking forward to painting the hubs and calipers but that's another thread. I used the "knuckle" just inside the rails on each side. My floor jack point isn't deep enough to use the rails - it would crush them first (of course the jack would have worked just fine). Actually was pretty painless although I like the idea about a slotted 2X4 - would minimize any paint scratching that may turn into corrosion later.
Old Mar 21, 2004 | 10:45 PM
Ned M's Avatar
If you have a hydraulic floor jack of the kind where the saddle is held in by a cotter pin, Eastwood Co. sells an adapter that fits your frame rail. It's a simple U-shaped piece of steel with a shaft welded on the bottom.
I've been using one for a number of years and it lets you jack the car via the frame rails but the floor jack is much faster than the jack supplied with the car. Can also use the floor jack and Mazda scissors jack together to lift up one whole side of the car to rotate tires.
Eastwood Co.
Old Mar 22, 2004 | 05:48 AM
flatso's Avatar
I'm Tantalizing
http://www.harborfreight.com/cpi/cta...emnumber=40105
this jack any good?
Old Mar 22, 2004 | 09:16 AM
G8rboy's Avatar
Eastwood Co.
That's cool- thanks for the info- I'll have to check if my cheap-o jack has a removable saddle.
Old Mar 22, 2004 | 09:17 AM
G8rboy's Avatar
this jack any good?
Yep- that's a real nice one. Harbor Freight usually has some pretty good deals...
Old Mar 22, 2004 | 10:04 AM
PUR NRG's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=40105 this jack any good?
WARNING Avoid Harbor Freight when quality is important!
They have great prices but really cheap quality goods. You do not want to skimp on quality when your life could depend on it. I've found these "racer-style" jacks leak hydraulic fluid under pressure and have poor release control. They can serve a specific use (say at a track when changing one tire at a time) but otherwise I'd avoid them.
One thing that complicates the situation is I've seen similar jacks advertised that look almost identical but have different hydraulic mechanisms. Quality varies immensely but it's hard to tell just looking at it.
________
PISSING LADY
Old Mar 22, 2004 | 01:46 PM
boarder's Avatar
So what brand/model would you recommend then ?
Old Mar 22, 2004 | 02:09 PM
PUR NRG's Avatar
I don't know of any mail-order lightweight jacks that I can recommend. The true racing jacks are $600 or so. I do have a similar lightweight jack (of better quality) that I only use to rotate tires. If I get under the car I use different equipment.
The jack I use at home and highly recommend is the AC Hydraulik. The DK20Q ($290) is a low profile jack and the DK12HLQ ($430)the extended reach version. You can get both of them here.
Jacks and jack stands are two critical pieces where an equipment failure can result in life-threatening injuries. It's not worth the risk to use low quality stuff.
________
Vision Insurance Dicussion
Old Mar 22, 2004 | 02:34 PM
blizz81's Avatar
Still, the endangerment for life and limb is usually null in terms of the jack itself if all you're doing is jacking up to put some stands down. Even if for whatever reason you're placing a stand towards the middle of the vehicle where you may put your body in danger, you can observe if the jack is operating well enough to support weight before sliding under to place the stand.
Basically just making the point that following suggested practices, 99.99999999% of people get by with the $40 craftsman floor jack/jack stand set for years without incident, and for a lot of those people, spending hundreds of dollars isn't very feasible. Of course, the choice of whether or not 0.00000001% of a chance * life and/or limb is worth spending those couple hundred dollars is something everyone has to make on their own.
Old Mar 22, 2004 | 02:46 PM
PUR NRG's Avatar
Price != quality. I would trust (and own) a $40 craftsman jack over a Harbor Freight knockoff. If nothing else craftsman is more aware and easily tracked down if/when a problem occurs.
Everyone makes trade-offs when it comes to safety, performance and price. Cars themselves are a great example of that. I just don't want anyone to operate under the mistaken belief that these are high quality race jacks. They are not. They are great for certian applications but don't rely on them if your life/limb is on the line should they fail.
________
Ebony Webcams
Old Mar 22, 2004 | 03:34 PM
ranger4277's Avatar
Cones need lovin' too!
If you have a good low-profile floor jack that will fit, the workshop manual says you can single-point jack the front at the center of the front crossmember, or the rear at the center of the diff. This would make it easier to get the jackstands in the proper places on the side sills. (and quicker!)
Old Mar 22, 2004 | 03:49 PM
XeRo's Avatar
Normality is Obscene
that's where i lifted the car in order to place my stands when I did my calipers, worked out perfect..
Old Mar 22, 2004 | 05:38 PM
flatso's Avatar
I'm Tantalizing
anyone have a pic of this location?
Old Mar 22, 2004 | 11:53 PM
MEGAREDS's Avatar
Goh Mifune
Bought a Floor Jack at Pep Boys this weekend... $40 -- as cheap as they come. I've not changed my own wheels before, so I'm very concerned about getting the right jack points. Can someone describe the most conservative points with enough detail for those of us with no experience?
Old Mar 23, 2004 | 12:26 AM
G8rboy's Avatar
You'll love it (compared to a sissors-jack). Here are the jacking points from the manual- if you look under the car at those points near the wheels, you'll see those compressed 'dots' in the reinforced part of the frame rail:
Old Mar 23, 2004 | 07:40 PM
JoeRX8ter's Avatar
Sears has a nice 3-1/2 ton floor jack with stands on sale for $99 this week.
Old Mar 24, 2004 | 12:07 AM
beachdog's Avatar
Ranger, can you post the diagrams for the front and rear? There was an old post that said not to use the diff because of aluminum housing. Does the manual say to support with wood between the jack and diff?
Old Mar 24, 2004 | 11:17 AM
rxeightr's Avatar
M0D Squad -charter member
Thanks for the heads up. I just ordered mine at sears.com, and will pick up later today at the store.
Old Mar 24, 2004 | 02:34 PM
beachdog's Avatar
Don't throw away the receipt. The saddle of the jack is probably low enough to get under the diff but probably not the front cross member. If it's the same Craftman jack that I bought. I wound up buying the 2 1/4 ton for the front to fit under the cross member.
