Oil Filling
Old Apr 27, 2012 | 01:31 AM
Keyo's Avatar
Exclamation Oil Filling
Hey, my 8 gave me the oil light tonight,so I checked the level and it's indeed low, now last owner have used Idemitsu Rotary Oil 10W30 and just like 2 month ago I put in the last quart. Problem is I forgot to order more from Mazdatrix since I don't use the car that much.since I don't have any tools in order to change the oil, would it be possible to just refill with 10W30 Fully Synthetic Royal Purple or will the blend mess my engine up?
I'm planning to use it just for like 100 miles and then I'm gonna drain the whole thing and switch permanently to Royal Purple. Or should I just drain the whole thing and put a new oil, Is there any recommended place to the oil changing? Thanks.
Old Apr 27, 2012 | 01:38 AM
ken-x8's Avatar
Top it off with any brand or type, as long as it meets the API spec in the owner's manual and is a viscosity you have faith in.
Ken
Old Apr 27, 2012 | 01:45 AM
Keyo's Avatar
Thanks You saved me a lot of hassle
Old Apr 27, 2012 | 07:26 AM
Like ken saids, any oil that meets API SL grade or later would be fine
And no matter what grade u use, it wilk work. U can mix 5w20 with 20w50
For the price of royal purple, i rather get amsoil or redline or mobil1 0w40, sometimes i feel a bit sick of rp's claim,i mean they make good oil and amsoil makes a lot of claim too ...
Old Apr 27, 2012 | 04:16 PM
Keyo's Avatar
I wanna match up the viscosity my engine is pretty is smooth with 10w30 im from l.a i think with the temps here it works pretty fine
Old Apr 27, 2012 | 04:26 PM
RIWWP's Avatar
Then get any oil with a weight of 30 as the 2nd number. The first one is cold, the 2nd one is warm, your car runs mostly under the warm viscosity.
All oils mix with all other oils completely. This really isn't as big of a deal as you are making it out to be.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
