Help Car will not Rev over 3500 RPM sometimes
Old Apr 21, 2012 | 09:36 PM
anoble1's Avatar
2004 RX8 Owner
Hi,
Was reading related threads on this issue. Mine seems a little different. I currently had my engine rebuilt. Got it put in and cranks fine. When I crank the car it will rev fine. About 10 seconds later it won't go past about 3,500 rpm. When I drive the car it does the same thing too. BUT, I have the DSC Off light. Along with the "skid light". I can cut the car for about 2 minutes and it will rev for about 10 seconds then throttle won't reach above 3500 rpm. Suggestions?
Old Apr 21, 2012 | 10:30 PM
paimon.soror's Avatar
start searching about the car going into limp mode. It can be caused by a number of things. start with the basics, maf sensor, ecu over heating, fuel pump, blocked cat
Old Apr 22, 2012 | 12:16 AM
Metering oil pump .....
And the no code thing is normal as well....
Old Apr 22, 2012 | 02:36 AM
anoble1's Avatar
2004 RX8 Owner
But I have oil in the lines.
Old Apr 22, 2012 | 02:37 AM
anoble1's Avatar
2004 RX8 Owner
Old May 3, 2012 | 05:07 PM
anoble1's Avatar
2004 RX8 Owner
Turned out to be the Oil Metering Pump Position sensor.
Old May 3, 2012 | 05:17 PM
We knew ...did you reset it successfully or buy a new pump?
Old May 3, 2012 | 05:21 PM
anoble1's Avatar
2004 RX8 Owner
Bought a used pump with sensor.
Shnifty
23
Dec 18, 2015 12:49 PM
vetteor8
Jul 25, 2015 11:43 AM
netrovers
Jul 20, 2015 03:32 AM
vssystemluba
Jul 19, 2015 04:16 PM
Belalnabi
Jul 17, 2015 07:48 PM
