Fuel Lines? Where do they go?
Old Apr 11, 2012 | 12:35 PM
anoble1's Avatar
2004 RX8 Owner
Hi,
I recently had my engine rebuilt last week. I am tryin to put in the motor. I have most everything connected except for the "fuel line"? I have the line with the Red clip hooked up to the fuel rail. But where does the fuel line with the blue clip go? The blue clip has a mounting bracket on the line. Any help? Pictures?
Old Apr 11, 2012 | 12:50 PM
bse50's Avatar
#50
There's a thing called workshop manual... you can find it on foxed.ca!
Old Apr 11, 2012 | 01:35 PM
hadlowj's Avatar
This should help
Old Apr 11, 2012 | 01:49 PM
anoble1's Avatar
2004 RX8 Owner
Hmm, that one is on the fuel rail. I think mine are connected their, but there seem to be 1 more on the car itself? So, another blue fuel line? Are there 2?
Old Apr 11, 2012 | 02:54 PM
Highway8's Avatar
Registered RX8 Nut
From my understanding, Its not a fuel line it is an evap line. Goes to the bottom of the upper intake.
Old Apr 13, 2012 | 08:44 PM
Jon316G's Avatar
Grasshopper
One end connects under the UIM (like it shows in Highway8's pic) and the other end will connect to a line above the rear spark plugs, next to the red disconnect.
The mounting bracket holds the fuel and evap line and is bolted to the bottom of the UIM.
I usually keep the bracket off because it can be a pain to remove the two bolts securing the bracket.
Old Apr 13, 2012 | 10:15 PM
anoble1's Avatar
2004 RX8 Owner
Sweet! Thanks guys. That was exactly it
Old Apr 2, 2018 | 12:50 PM
Red line envy's Avatar
Which fuel line needs this. Did I lose all but one or do I only need one. Putting engine back in after a rebuild.
Old Apr 2, 2018 | 12:54 PM
NotAPreppie's Avatar
What am I doing here?
All the fuel lines have the same fitting from the factory. They may differ on color or whether they are 90° elbows or straight, but the connection point is the same.
I don't recognize that one. Looks like it might be from an aftermarket replacement or a random piece of plastic completely unrelated.
Are you missing a fuel fitting?
Old Apr 2, 2018 | 01:07 PM
Some on the connections have this piece, some do not.
Old Apr 2, 2018 | 01:09 PM
I’m thinking it’s the one straight red connection that takes this.
Old May 23, 2023 | 01:36 AM
RN-RX8's Avatar
I had one of those come out of my fuel pump quick disconnect... the other ones were missing from the other quick disconnects.
Old Oct 5, 2024 | 11:13 AM
Qonjin's Avatar
Unhappy part number for the stopper or plastic seal clip
Unfortunately my little plastic basket that goes in the red line got stepped on does anyone know the (part number)? Or do I need to order new fuel line, maybe S2 has upgrade fuel line compared to RX8 S1?
Old Oct 7, 2024 | 02:27 PM
gracer7-rx7's Avatar
I just ordered a new fuel line. It is slightly different where neither end had that basket. I suspect whatever hose they have now is probably the S2 or 3 and supersedes / replaces the old ones.
Old Oct 8, 2024 | 07:18 PM
ditto's Avatar
From what I understand, the blue clip line should connect to the bottom of the upper intake manifold. But I could be wrong, still learning about these engines myself.
Old Oct 11, 2024 | 05:11 PM
Qonjin's Avatar
Do the yellow tabs come off the new fuel lines or stay on?
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
