advice on running my rx8
Old Mar 31, 2012 | 07:11 AM
cjanddee's Avatar
Hi
I bought a rx8 192 (2005) last week and so many people are given me different advice on how to run it, i kinda understand the way the rotary engine works but im told you have to be careful not to flood the engine and this is easily done by stop starting when its cold, so in effect im not able to just pop to the shop 2 mins away ???
if this is the case then im going to struggle to get used to this.
also i dipped the oil and found creamy sludge on the stick, again i was told this is normal for the rx8 ????
can anyone answer these issues and advice me on how i can prevent my car from flooding, oh i was also told that this particular year model was modified to stop the flooding, is this true ???
many thanks
cj and dee
Old Mar 31, 2012 | 07:18 AM
Huey52's Avatar
Registered Zoom Zoomer
Mid way thru the 2005 model year an uprated starter and stronger battery were substituted. There was also a voluntary (free) recall for same for prior manufactured 8's. If you have the stronger starter and a good battery you need not worry about the cold start flooding issue. There's of course already a detailed thread on this.
Correct, the milky oil is simply condensation and not an issue. There's of course already a detailed thread on this.
There's of course already a detailed thread on everything related to this vehicle at this point..
Old Mar 31, 2012 | 10:50 AM
New Yorker's Avatar
Yeah, just read the sticky for new owners - you'll find most of the answers you're looking for right there.
Regarding the milky tan substance on the oil dipstick: it happens in very cold weather and is inconsequential. But it is disconcerting; Mazda issued a Technical Service Bulletin (TSB) to its dealers with a fix. So if it bothers you, the dealer can install a part that will stop that from happening.
Enjoy your new 8!
Old Mar 31, 2012 | 12:33 PM
cjanddee's Avatar
Many Many thanks for your reply, that has eased my mind ill look into that recall and for now ill try not worry about the cold start and flooding issues, you have been a great help to this newbie
cj and dee
Old Mar 31, 2012 | 12:37 PM
cjanddee's Avatar
Thanks very much for your quick reply your answer has def taken a weight off my shoulders, i have no need to go 10 miles to the shop that is only 500 yards away just to get the engine warm enough to turn off.
you have been a gteat help
cj and dee
Old Apr 22, 2012 | 05:40 AM
cjanddee's Avatar
Hi
why is it i can drive my rx8 for about 20 mins so its well warmed up, but if i pull into the fuel station and fill up i have real trouble starting it again, maybe 4 attempts and it will start, i dont understand why it does this as the temp gauge is at normal ?????
many thanks
cj
Old Apr 22, 2012 | 05:51 AM
bse50's Avatar
#50
It may be a fuel pump issue, especially if you're over 60k miles.
Other than that it may be a compression problem or a clogged catalytic converter.
Old Apr 22, 2012 | 10:39 AM
Huey52's Avatar
As cited by bse50, typically marginal fuel pump or low compression.
Again, there's a thread for that (as everything else at this point): https://www.rx8club.com/showthread.p...t=warm+restart
Old Apr 22, 2012 | 03:54 PM
LytHka's Avatar
Or coils.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
harithac
Jul 31, 2015 09:57 PM
dbarber
Jul 25, 2015 01:34 PM
RX7.9
Jul 20, 2015 12:01 PM
