cat /air pump delete
Old Mar 20, 2012 | 08:47 PM
200.mph's Avatar
FULLY SEMI AUTOMATIC
Those running catless n/a who has removed the air pump? Have you had any issues?
Old Mar 20, 2012 | 08:52 PM
redline86's Avatar
The Heavy Metal Scientist
Just removed mine this weekend and put racing beats cover plate over the manifold. No issues at least for the past 2 days. Now my question is why bring it up? Are you having issues?
Jake33's Avatar
Dudemanbro
sort of want to remove mine also, as it barely works
Old Mar 20, 2012 | 09:30 PM
No issues except a CEL
and smelly exhaust
Old Mar 20, 2012 | 09:39 PM
redline86's Avatar
Some of us don't even have that
Old Mar 20, 2012 | 09:57 PM
Creto's Avatar
It's good to be the king.
O2 spacer?
Old Mar 21, 2012 | 06:24 AM
200.mph's Avatar
i brought it up because im catless and ordered the rb plate. just wanted to meke sure there were no issues and that you can remove the whole thing
Old Mar 21, 2012 | 06:33 AM
xexok's Avatar
Originally Posted by Creto
O2 spacer?
Some of the earlier rx8s(maybe just 04s?) get lucky and don't really ever get a cel for a midpipe. Some people are just lucky, I have an 09 and mine takes 300+ miles to come on and usually much more than that. Even when it comes on its usually just to say the o2 sensor is seeing a strange reading, I hardly ever get the p0420 code for the cat. I just have the o2 sensor in there normally, nothing special done.
Old Mar 21, 2012 | 06:36 AM
200.mph's Avatar
i havent had a cat for a few years but i have a cobb now
Old Mar 21, 2012 | 11:39 AM
redline86's Avatar
O2 spacer?
Nope, the blackest of black magic.
None that I have heard of, this might help though https://www.rx8club.com/series-i-tech-garage-22/air-pump-delete-193675/
The backing plate is easy to install with good socket extensions. Read down and Team gives a rough explenation how it is done easily. Took all of 15 minutes to remove everything. I left all the wire harnesses in place or zip tied them down.
Old Mar 21, 2012 | 12:10 PM
200.mph's Avatar
thanks thats the thread i was looking for
Old Jan 27, 2016 | 07:07 PM
Hunterkelley24's Avatar
Sorry to reopen this thread back up but is there anywhere you can still get the little plates to cover up the ports ive looked everywhere and searched racing beat up and down and still can't find one . Anyone know where I can get one ?
Old Jan 27, 2016 | 07:43 PM
Chrishoky's Avatar
Exhaust Manifold Air Injection Cover Plate for 04-11 RX-8 - Racing Beat
Old Jan 28, 2016 | 02:15 AM
I love you !!!! Do I need 1 or 2 ? I thought I seen where there's 2 ports ??
Old Jan 28, 2016 | 02:19 AM
They don't have them anymore tried to buy and it said they moved them somewhere else ....... 😢😢😢😢
Old Jan 28, 2016 | 07:37 AM
Creto's Avatar
Just 1. You can visually see this from the engine bay by following the metal pipe from the air pump down to the exhaust manifold.
Old Jul 10, 2019 | 05:50 PM
40th8Jake's Avatar
REW Club
I have searched to no avail.
Resurrecting this thread in lieu of being roasted for starting one about this but.. here goes:
Just had racing beat headers installed by mechanic. Would of done it myself but a lift makes it a lot less painful ( have to take motor mount off etc). Anyhow got a BHR Midpipe and racing beat catback exhaust with Versa Tuner lite tune on it and a code for the cat disabled. So I didn’t have the mechanic touch the air pump. I have to reinstall the cat and re-flash the stock tune for emissions every two years.
Now will it hurt to run my car with the air pump without a catalytic converter? (Maybe melt the resonator material in the Midpipe?). Any performance loss by doing so? I’d prefer to leave it since it’s one less headache when swapping the Midpipe back for stock cat for emissions. - Thanks in advance
Old Jul 10, 2019 | 06:28 PM
200.mph's Avatar
no the air pump is there for cold starts to warm the cat of some ****, you will be fine. you can unplug it if you want
Old Jul 10, 2019 | 06:32 PM
Ricky SE3P's Avatar
Project Seca
You can leave the secondary air injection pump as well as the pipe which connects it to the header in place without any consequences.
Old Jul 10, 2019 | 09:17 PM
40th8Jake's Avatar
REW Club
Thank you men for the timely response. You are saving me from the extra work of taking it apart to only put it back together again down the road. May the brothers of the rotary ride on. -Thanks, Jake
9krpmrx8
157
Sep 19, 2023 02:20 PM
smogapi
Jun 24, 2014 10:09 PM
hyunghong08
Mar 3, 2012 08:05 AM
rx8t20046sp
Feb 19, 2011 05:32 PM
heilander
Mar 15, 2010 06:19 AM
