MazdaSpeed Springs With 40th A.E. Bilstein or Mazda Speed Shocks?
Old Mar 12, 2012 | 10:35 PM
Federighi's Avatar
Hi,
Couldn't find any direct input specifically A & B'ing the subject. Does anyone have any experience using the MS spring with OEM Bilstein's &/or MS shocks? Which did you prefer & why? Any valuable comments or observations are greatly appreciated.
Thank you.
Old Mar 16, 2012 | 10:47 AM
Evolv's Avatar
Originally Posted by Federighi
Hi,
Thank you.
I have a 40th edition and I recently went through all the BS to find out whats different with our suspension.
In the front - nothing has changed
In the rear, Mazda raised the perch height by 15mm and increased the shock length by 10mm.
This sucks because we are now limited to the OEM Bilstein's or Koni 8240-1280 Sport shocks.
With that (and I will confirm this next week) our spring length in the rear is also different the the NON-Bilstein RX8's.
So the bottom line, use your OEM springs or buy coilovers.
If you talk to Racing Beat they will tell you that their springs do not match the Bilstein suspension and from my understanding the Mazdaspeed springs are identical in length to the RB's.
I will be pulling the suspension out of my 40th Ann next week and I will compare some measurements and report back.
Old Mar 16, 2012 | 12:49 PM
Federighi's Avatar
Great. Look forward to hearing about your observations.
Old Apr 12, 2012 | 11:13 AM
EricB's Avatar
#225 of 1000
update? Isnt this essentially the same issue S2 owners have? which isnt essentially a problem since everything works as it should. Though i remember 9k saying he worked on a 40th anny and put tein s techs in.
Old Apr 14, 2012 | 01:13 PM
Evolv's Avatar
I haven't pulled my suspension out but plan to in the next week or so.
I ordered coilovers and just got the parts in a few days ago.
Once the OEM springs are out I will take the measurements and report back.
Old Apr 14, 2012 | 03:10 PM
EricB's Avatar
#225 of 1000
thanks, i was going to buy sprint springs but someone else bought them.
Old Jun 6, 2012 | 05:19 AM
vy_MR2's Avatar
Can anyone confirm whether the MS springs can be used on a 40th anniversary?
Old Jun 6, 2012 | 09:27 AM
EricB's Avatar
#225 of 1000
yes. All rx8 lowering springs will work on all factory shocks.
If you have a 40th, i reccomend the sprint springs. 2inch drop, perfect ride height. I parked alittle close to the curb with my front lip today and i was happy to find out my lip cleared it with like 5mm
IMHO MS springs are not worth the cost, and springs in general are not worth the cost if you are not installing them yourself. I was charged 400 to install them and i got my set used for sub 300
jay_tibo
22
Sep 13, 2016 08:10 PM
WingleBeast
22
May 23, 2016 09:22 PM
SupraG
Sep 21, 2015 12:09 AM
dohon
Aug 1, 2015 01:46 PM
AussieGray
Jul 16, 2015 03:58 AM
