ssv wiring
Old Feb 29, 2012 | 03:25 PM
pingg20's Avatar
ssv wiring
ssv wiring-ssv%2520assembly.jpghi all, got a small issue with what i think is called ssv actuator, the thing is i fitted a new engine from a 55 plate to a 04 plate and noticed that on the 04 the ssv has a switch but on the 55 the switch is linked out .is this a mod on newer engines and will it affect the performance on the 04, as i cant get the car to go any faster than 97 mph cheers
Old Feb 29, 2012 | 03:30 PM
Brettus's Avatar
Boosted Kiwi
what do you mean by "linked out " . Do you have pics of both setups ?
also - you can verify that the SSV is working by having someone turn off the engine while you watch the valve . It should do a quick on-off cycle .
Old Feb 29, 2012 | 04:59 PM
pingg20's Avatar
these are the to different ssv pics , will check the working state of it in the morning cheers
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
