Cranking injector pulse width
Old Feb 25, 2012 | 02:37 PM
oltmann's Avatar
I think I found a couple tables for setting cranking IPW based on coolant temp:
Code:
Table A
Coolant Temperature [c],Cranking IPW [us]
-30,123700
-25,121000
-20,112400
-10,65000
0,43300
10,34700
20,28100
30,22000
40,17500
50,14200
60,11870
70,10170
80,8135
Table B
-30,123700
-20,112400
-10,65000
0,43300
10,34700
20,28100
30,22000
40,17500
50,14200
60,11870
70,10170
80,8135
They are shown here with the scaling from the rom, which looks to be microseconds, so divide by 1000 to get IPW in milliseconds.
There is also a table which acts as a multiplier to these values based on throttle position:
Code:
 [Throttle Position], [Multiplier]
21.02102,1
22.52252,0
100,0
So in the stock configuration it just disables this enrichment if you floor it, but there might be other interesting ways to set it up.
caveats
There are other checks against pedal position, throttle, ECT and unknowns, that can disable this enrichment. Also unknown is exactly under what circumstances table A or B will be used, and there are other modifiers to the final value, including some learned parameters, that I don't understand. This is all totally untested.
Almost forgot, I looked these up in some other roms for reference:
Code:
Series II 2010 MT USDM
-30,91230
-25,89240
-20,82895
-10,47940
0,31935
10,25590
20,20725
30,16225
40,12905
50,10475
60,8755
70,7500
80,6000
Very early JDM
-30,123745
-25,121030
-20,118310
-10,103220
0,90130
10,72270
20,46835
30,35465
40,25140
50,17450
60,11870
70,10170
80,8475
Old Feb 25, 2012 | 10:11 PM
You appear to be making good progress.
Old Feb 25, 2012 | 10:39 PM
Brettus's Avatar
Boosted Kiwi
good stuff . Would be great if you could find cranking coil dwell as well
Old Feb 26, 2012 | 04:58 AM
oltmann's Avatar
I've looked at that a few times, but I still think cranking dwell is set by a single parameter. Not something you'll be able to change with ProTuner as it is.
92trbolzr
May 18, 2025 09:04 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
Luke.s
Sep 30, 2015 05:57 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Rote8
Sep 22, 2015 03:43 PM
