20w 50 for rx8?
Old Feb 13, 2012 | 06:25 AM
musicaddikt's Avatar
20w 50 for rx8?
I am thinking of changing my oil to 20w 50 mineral silkolene. Here in Malta is moderate climate, what you think??
Old Feb 13, 2012 | 07:12 AM
jasonrxeight's Avatar
try glue
super glue is the best cuz its thick as hell when dry
Old Feb 13, 2012 | 07:59 AM
bse50's Avatar
#50
It's not a smart idea, especially with the stock oil pressure regulator.
Old Feb 13, 2012 | 09:34 AM
1.3_LittersOfFurry's Avatar
Flame On!
^why? In manuals for other countries they recommend 20w50 for certain climates.
I personally use 10w40 myself.
Old Feb 13, 2012 | 09:41 AM
bse50's Avatar
#50
Don't know what manuals you're referring to... the us one says to use crappy 5w20, in europe the recommended viscosities range between 5w30 and 10w30.
I always used a good 10w40, even before changing my oil system's pressure.
Malta is very close to italy, 20w50 is definitely too much both climate and oil system capabilities wise.
Old Feb 13, 2012 | 10:24 AM
rickeo's Avatar
running on double cream!
^ The FSM in the US actually says to use 5w20... :O
Old Feb 13, 2012 | 10:39 AM
AZ R3's Avatar
iZoom
FSM?
Not only does the manual say 5w20, but you are only supposed to change your oil every 5k miles :D
Old Feb 13, 2012 | 11:30 AM
comebackqid's Avatar
I use 10-40 myself I think if you're in a place where the temp will reach over 37.7 C I don't see anything wrong with running 20-50 I've used it before during the summer months with out any issue I live in southern california so temps in summer will exceed 37.7 C (100 degrees F) so I sometimes run 20-50, but if it's mild there I think 10-30/10-40 should be fine.
Old Feb 13, 2012 | 12:15 PM
Flame On!
Originally Posted by bse50
Don't know what manuals you're referring to... the us one says to use crappy 5w30, in europe the recommended viscosities range between 5w30 and 10w30.
I'll post the pic when I get home, I beileve it's for Australia.
Old Feb 13, 2012 | 12:38 PM
xexok's Avatar
Is this what you are referring to furry? Couldn't find a better picture than this.
Old Feb 13, 2012 | 01:43 PM
Flame On!
Yeah, that looks like it. I wouldn't listen to the US version.... 5w20 is garbage for rotary. I always used 20w50 in my FC's year round with no issues.
I used 5w30 when I first got mine, but at 300 mile intervals for 900 miles to help get kind of a flush since the original oil looked so bad. After that it's been 10w40 for about 10k miles now.
Old Feb 13, 2012 | 04:18 PM
xexok's Avatar
Yep I have been using 10w40 since I got the car at 18k miles also. Seemed the best choice based on the little chart and from reading on here. Now I am at 37k miles and still running great(knock on wood).
Old Feb 13, 2012 | 07:32 PM
pdxhak's Avatar
Official Post Whore
That chart say it is ok to use 20w-50 between 0*-120* F?
Old Feb 13, 2012 | 07:35 PM
nguise24's Avatar
Batman
you will have better engine life using 20 50, if you use 5 20 like i did it will eat up the seal, and blow your engine eventually like the situation im in.
Old Feb 13, 2012 | 07:40 PM
pdxhak's Avatar
Official Post Whore
I have been using Castrol full synthetic 20w50 since Dec 2010.
Old Feb 13, 2012 | 08:38 PM
monchie's Avatar
I HATE SPEEDBUMPS!
I'm still using 5w-20, the recommended one, no major problem so far.
Old Feb 13, 2012 | 09:43 PM
Flame On!
Yes, but if you think it will be that cold I would go with 10w40 or 10w30.
Old Feb 13, 2012 | 11:32 PM
RX8RX7's Avatar
Originally Posted by jasonrxeight
try glue
u mean it's hard as hell when dry ?
FC has weaker oil pressure regulator but still survive the 20w50. all year long.
I use 20w50. 15 degrees a month ago. no issue. Well, a GOOD Synthetic 20w50. Not some Autozone junk
Old Feb 13, 2012 | 11:39 PM
Well I will not use any synthetic or semi syn, absolutely not, it will damage the seals. I will run 10w 30 mineral and see how it will run.
Old Feb 14, 2012 | 12:22 AM
spgcyn's Avatar
HAHAHAHAHAHAHAHAHAHAHA
stop spreading **** u know nothing about. god.
Old Feb 14, 2012 | 07:43 AM
ken-x8's Avatar
... the us one says to use crappy 5w30...
I'm in the US and my manual says to use good 5w20.
Besides that page from the Australian owner's manual, one edition of the shop manual lists all of those oil grades without even specifying temperature ranges. No wonder everyone argues about which to use!
Ken
Old Feb 14, 2012 | 08:01 AM
bse50's Avatar
#50
Ken
You're right, typo on my side! It's our manual that states to use 5w30
Old Feb 14, 2012 | 08:15 AM
RotaryTherapy's Avatar
Old Feb 14, 2012 | 08:18 PM
Aseras's Avatar
In the summer in florida I ran 20W50. 5w20 turns into water. 10w40 even gets thin. had over 110k miles on my 2004 rx8 before that engine was replaced after an accident, still ran awesome and had good compression. Make sure you premix though. the thicker oil doesnt inject nearly as well.
Old Feb 14, 2012 | 08:40 PM
zoom44's Avatar
yeah i dont see any issues and do see some benefits with running 20w50 if the climate is anything like louisiana alabama georgia or florida.
