Gear changing issues
Recently I'm finding it hard to change gear especially when it's cold, also when changing gear there is some kind of engine jerk, it feels like something isn't connected properly in the linkage or transmission.
Is there anything I can look at such as greasing linkage / gear stick or looking to see if linkage loose?
All help would be great thanks so much!
Wild guess on limied info is you might be hitting early stages of an issue with the throwout bearing.
Its a 192 Manual 5 Speed.
Has 65k on the Clock and has no mods what so ever except a de-cat. The previous owner had said it was fitted with a new clutch kit but there was no paperwork provided with that. There is no information on the transmission oil being changed too.
The clutch itself feels fine and pulls strong no slipping its almost like there is a clonk in the engine bay area and jolts the car, yeah its very stiff to change from any gear to be honest.
Its only happened last few thousand miles, I remember i had a similar problem with a renault years ago and turned out to be a "Dogbone" mount underneath the car to the engine and the gear linkage bolt was loose.
Any thoughts?
Any thoughts?
If you are at 65k without a transmission fluid change(or without knowing if its done) that should be where you start. A lot of people change it much earlier than that. Search around to see what oil most people are using and then change yours.
Have you actually inspected the trans oil yet? If you want to try going the cheap route you could just remove the filler cap and dip a finger in there and see if it looks burnt or bad. Maybe since series 1 rx8s can fill from the shifter you could also dip from there with something? I have no clue on that, but maybe someone can enlighten me.
How would i be able to check the tranny fluid inside the gear stick? Where is the easiest place to access it so i can see the colour of it etc.
What about engine mounts could this potentially be a problem for the gear changing?
Well sometimes i hear a little squeak if im not driving and press it but i think thats just normal?
I just never get why every time i change gear it struggles to change and i also get a jolting from the car :/
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Dokuji
Nov 1, 2016 02:51 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
