Newly cutted fob blade is not cranking the engine
Old Jan 29, 2012 | 12:54 PM
balli69's Avatar
B@LLi69
Hello everyone, I have a problem here and hope u can help me. i have 05 rx8, bought it used with 1 normal key and 1 switch blade keyless entry remote.
i lost my keyless entry remote and after that i bought one keyless entry remote with un-cut blade from ebay, i programe the switch blade keyless entry remote and its working fine, doors, trunk and panic buttons are working properly. today i took that remote and my simple key which i got with my rx8 to mazda dealer to cut the blade (rx8 is parked in my garage because of snow). after coming back i try to start the car with new cutted blade but nothing, let me explain u in details, i gave the simple key and my newly programmed remote to dealer and he cut the blade.
i can open close the doors with that and when i put new key blade in ignition it turns smoothly and show all lights normal but when i try to crank the enging nothing happend and a key sign light start blinking fast. the bottom line is "new blade doing everything but not cranking the engine"
Any helps?
Thx in advance
Old Jan 29, 2012 | 01:21 PM
Need to program the key
Old Jan 29, 2012 | 02:08 PM
balli69's Avatar
B@LLi69
u mean the key in rx8's remote need to programe? remote is working fine and blade key in remote is open n close the doors and switch on, off and does everything but not crank the engine only. remote key blade is cutted same as the normal key which i was using and works fine starts engine.
Old Jan 29, 2012 | 02:17 PM
RX8Soldier's Avatar
Time for boost...
search the diy forum for how to reprogram the key.
Old Jan 29, 2012 | 03:11 PM
Both the key and remote need to be programmed into the security system.
Old Jan 29, 2012 | 03:42 PM
balli69's Avatar
B@LLi69
from dealer?
Old Jan 29, 2012 | 04:18 PM
If you have 2 functioning keys you can DIY.....search for the DIY
Old Jan 29, 2012 | 04:25 PM
balli69's Avatar
B@LLi69
no, i have only 1 which is simple old style. any solutions?
Old Jan 29, 2012 | 04:55 PM
Dealer or a locksmith that has a programmer
Old Jan 29, 2012 | 06:51 PM
Grace_Excel's Avatar
Charles Bundy
You're the second person to ask for help of the same exact problem in the past three days
Old Jan 29, 2012 | 09:45 PM
balli69's Avatar
B@LLi69
ok, thx
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Pelleilee
Sep 29, 2019 10:07 AM
Kim Jong Illest
Aug 6, 2015 02:34 PM
