Buying an RX-8
Old Jan 17, 2012 | 03:24 AM
bonesmen888's Avatar
Buying an RX-8
Found an 2003 RX-8 to buy with 80k Miles. Did a compression test with the following results.
4 sparks tested:
1st. 80 psi
2nd. 80 psi
3rd.80 psi
4th. 60 psi
The car takes 2-3 seconds to start and it has that for the past 4 years. It has been changed 2 times the sparks and once the coils.
If i buy this, is the engine gonna die on me any soon?
Any suggestions would be appreciated.
Old Jan 17, 2012 | 05:16 AM
R80MAV's Avatar
im no expert, not even the owner of an rx8 yet, but im sure the results are supposed to read differently to this. there should be 3 readings from each rotor giving the compression figures from each face. something like this:
"Rotor #1: 770/750/750 kPa at 276 RPM
Rotor #2: 770/780/750 kPa at 280 RPM"
Old Jan 17, 2012 | 07:18 AM
Wingznut's Avatar
Go Red Wings!
It sounds like the compression test was done with a typical gauge made for piston engines. If so, the results are completely irrelevant and you'll want to get the test done with the proper equipment and methodology.
ouimetnick
25
Sep 14, 2023 01:44 PM
Nisaja
Apr 14, 2019 08:04 AM
Kahl
Aug 20, 2015 11:49 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
Lee_1420
Aug 10, 2015 01:05 PM
