clutch problems?
Old Jan 13, 2012 | 04:26 PM
br0wm's Avatar
ON clutch problems?
im recently having problems with my clutch as it is not really grabbing the gears like it use too?
i think i need a new clutch
does anyone have any suggestions on a good, not so expensive clutch?
and whats the difference between stage 1, stage 2, stage 3 etc?
what are the things i should be interested in?
Old Jan 13, 2012 | 04:30 PM
FastFreddy61's Avatar
Can you explain "not really grabbing the gears". Is it slipping, grinding, not engaging ?
Old Jan 13, 2012 | 04:40 PM
br0wm's Avatar
its really not engaging
Old Jan 13, 2012 | 04:53 PM
A few things to check first, Is there sufficient fluid in the reservoir, how much free play do you have at the pedal, how many miles on the clutch, has the oil in the tranny been changed in the last 30k miles, if it has, which oil was used .
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
