Mazda Takes a Different Approach
Old Jan 12, 2012 | 05:45 PM
zoom44's Avatar
Old Jan 12, 2012 | 06:27 PM
Old Rotor's Avatar
I liked it....low key...
Old Jan 12, 2012 | 06:59 PM
RXeligion's Avatar
The X is silent
At 3:03, when they do the engine cutaway, it appears as if pistons are paired up at the crank position (and in operation) like the motor is running as one big-*** 2-cylinder, with managable compression. I've never seen that in a 4-banger before.
Old Jan 12, 2012 | 11:17 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Change is good. Anyway, i was hoping for a newly rotary-powered Mazda, replacing the outgoing rx8.
Old Jan 13, 2012 | 04:02 AM
ASH8's Avatar
Super Moderator
Current MZR has the same configuration...I think the firing order is the same as MZR, but not 100% sure.
Old Jan 13, 2012 | 04:08 AM
bse50's Avatar
#50
de fuel consumption probrem!
Old Jan 13, 2012 | 06:45 AM
MattMPS's Avatar
Wiseguy
uere is za purobulem?
Old Jan 13, 2012 | 07:14 AM
Mazmart's Avatar
http://www.youtube.com/watch?v=0Ge65pSpJPg
Almost all INLINE 4 cylinders in the world use a 1-3-4-2 firing order so 1 and 4 would rise simultaneously as would 2 and 3. I remember some cars running 1-2-4-3 when I was a youth but I don't know if that still exists (Old British Fords). Subaru uses a 1-3-2-4 on their boxer engines.
Paul.
Old Jan 13, 2012 | 09:25 AM
rotarygod's Avatar
That firing order looked normal to me. That's what Honda does.
Old Jan 13, 2012 | 12:20 PM
there really aren't many new approaches, just new technology that allows them to explore what was discovered and hypothesized many years ago in early combustion engine history
Old Jan 14, 2012 | 02:56 AM
ASH8's Avatar
Super Moderator
Agree..
Old Jan 14, 2012 | 11:07 PM
RXeligion's Avatar
The X is silent
Yup, You're right. For some reason, my mind registered the operation of the paired pistons as being on the same stage of the compression cycle (two sucking simultaneously, instead of one sucking, one blowing.) Chalk it up to a brain fart...
Old Jan 15, 2012 | 12:04 AM
ok, where is the next Rotary Engine ?
nothing to see here. move on.
Old Jan 24, 2012 | 04:30 AM
ASH8's Avatar
Super Moderator
Fuel Figures confirmed for CX-5 Diesel for Australia...
And coming to the USA soon!
http://www.goauto.com.au/mellor/mell...25798E0002DF3D
http://www.theautochannel.com/news/2...nd-torque.html
USA Confirmation on Diesel
http://carscoop.blogspot.com/2012/01...model-for.html
Old Jan 24, 2012 | 05:47 PM
Mazmart's Avatar
Thanks Ash,
the figures on the 2wd CX-5 work out to 62 mpg hwy with around 52 mpg for the 4wd version. Very impressive indeed.
Paul.
Old Jan 24, 2012 | 07:53 PM
ASH8's Avatar
Super Moderator
They are ON THEIR WAY to America's!..
Old Jan 26, 2012 | 02:18 AM
ASH8's Avatar
Super Moderator
CX-5 2.2 SA DIESEL Production started Today.
Mazda will start introducing the Mazda CX-5 diesel this spring in Japan, Europe, Australia, followed by other markets around the world.
Old Jan 26, 2012 | 07:32 AM
Mazmart's Avatar
Ash,
Has the petrol version gone to Europe, Australia, Russia and other territories as yet?
Obviously I know the ship in the video is US bound.
Paul.
Old Jan 26, 2012 | 09:21 AM
MattMPS's Avatar
Wiseguy
Based upon infos founded in a german Mazda forum, first gasoline-powered Cx-5s will arrive in Western Europe in July.....
Some people here in EU have placed a order without seeing a car "in flesh&bone"......
Old Jan 26, 2012 | 01:06 PM
ASH8's Avatar
Super Moderator
Ash,
Paul.
AFAIK some are here (last week)....due for launch in March, Diesels arrive next month.
BTW...The RX-8 was removed from Mazda Aussie new vehicle line up this week!
Old Jan 26, 2012 | 02:41 PM
fastlaneracing's Avatar
Rotor User
I do like the cx-5, may trade in My 2011 6 touring for one.
It may help fund next gen Rotary too
Old Jan 27, 2012 | 03:05 PM
ASH8's Avatar
Super Moderator
Mazda CX-5 Part Numbers are up for those (not) interested...for the 2013 KE Series CX-5
CX-5 AWD is ONLY available in 6 Speed Auto, Manual ONLY FWD with Cable controlled Stick Lever.
Also have full 2.2 SkyActiv Diesel Engine Parts Info...and she is a "shy one"...SHY1-02-300
And a SH01....SH01-10-271 Head Gasket, SH01-10-090 Cylinder Head, etc, etc.
The 2.0 SkyActiv Engine Parts info is basically the same as Mazda 3 SA, except the full SA features like the 4:2:1 Exhaust Manifold or referred to as a "Converter" and will run around the $1000 US mark!...these are not NA Region PN.
PE02-20-50XA Converter 2WD Aust
PE07-20-50XA Converter 2WD UK
PE39-20-50XA Converter 4WD
Panels..
KD53, KD54.
Front Axel set up, similar to Mazda 3 , Knuckle, Wheel Bearing Hub, Lower Control Arm (A), looks like steel to me...and Shocks
Rear, Hub (similar to RX-8), Single Steel Trailing Arm/Bush, Single Lateral Link, and a "Banana" Upper Arm, so a total of 3 links each side for the Rear with paddle shape Lower Arm where rear coils sit in...and shocks are separated from rear coils .
Happy to take some requests, at this stage no images...most of this stuff is still embargoed.
Old Jan 27, 2012 | 03:25 PM
ASH8's Avatar
Super Moderator
More simple stuff for the KE Series CX-5...
Colors..
16W Black Mica
27A Velocity Red Mica
34K Crystal White Pearl Mica
35J Stormy Blue Mica
36C Metropolitan Gray Mica
38P Aluminum Metallic
41B Sky Blue Mica
41G Zeal Red Mica
A4D Arctic White
Interior..
KC3 Black
KC4 Black/Sand
Old Jan 27, 2012 | 03:44 PM
ASH8's Avatar
Super Moderator
Looks like Aust does not get the 'Lane Changing Aid', there are 2 Control Modules, one on the left side and one for the right side, and are around $800 US Each...total $1600 just for the Control Modules!!...but we do get OE Rear Parking Sensors.
Sunroof we get.
Sound, up to 9 Speakers, one in EVERY Door, two in the rear, 3 across the Dash...for Aust.
Overhead Console, similar to RX-8, and Sunroof.
UK gets 4 and or 6 Speakers.
All with a Single Amplifier..which is very good!
Old Jan 27, 2012 | 06:54 PM
Mazmart's Avatar
Hmm, KE and the SHY SHO! Sounds like a band.
Thanks Ash!
Paul.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Mxttz0r
Jul 5, 2019 03:19 AM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
Belalnabi
Jul 17, 2015 07:48 PM
