Searching to no Avail: Changing Hi-Beams How?
Old Jan 12, 2012 | 04:26 PM
Globetrahter's Avatar
So I searched and what I searched on google was RX8club DIY changing hi-beams but nothing really came up and the board has been empty as of late for some reason or dead I should say
But is it hard to change the Hi-Beams on the 2004 Headlight? Do I have to do anything like unbolt anything on the headlight assembly?
I read how to do the parking lights and we were able to do that but I never looked at Hi-Beams until I recently purchased some
Old Jan 12, 2012 | 04:34 PM
RIWWP's Avatar
I'm not surprised you didn't find anything. Only a handful of RX-8s (comparatively) have "bulbs to change", so it's a very tiny subset of people that would even be interested in posting about it.
Nearly all RX-8s got the HID headlights which last nearly forever and are quite expensive as a replacement if the ballast goes bad. Not a bulb replacement at all.
If you actually do have a non-HID RX-8 (pretty much the base automatic 2004s and 2005s only, and even many of those did) then it should be a simple connector, a spring retainer, slide the bulb out, new one in, reset the spring, and reconnect. All my other Mazdas have been identical to this.
94,000 miles on my 8 and my HIDs haven't even dimmed slightly.
You have a GT trim according to your sig, and thus have HIDs. If you have a headlight out, search instead for HID Ballast replacement. It's not gonna be cheap.
Old Jan 12, 2012 | 04:52 PM
O No Man, not the actual HID but just the Hi Beams which is not HID. It's an H9 Bulb. My HID's are still working perfectly.
Old Jan 12, 2012 | 04:58 PM
RIWWP's Avatar
Ah, understood.
Well, it should be the same sequence mentioned for the bulbs in my post. Should be a connector on the back of the light, remove that, then remove a rubber boot cover, release the spring, remove the bulb. Replace in reverse order. I can check when I head out to my 8 in an hour or so after work.
Old Jan 12, 2012 | 05:01 PM
Ah, understood.
Cool, Ill check too.. Im off now but I work in tech support and someone has a Damn Mail issue!
RevMeHarder
Jun 1, 2026 02:30 PM
tallestmexican
May 1, 2018 07:22 AM
TJSiegrist
Sep 10, 2015 09:29 AM
iwannarun
Sep 6, 2015 01:37 PM
Rupanrx
Sep 4, 2015 06:44 AM
