Keyless Remote
Old Jan 7, 2012 | 05:53 PM
pfbaseball's Avatar
Keyless Remote
Hi All,
Say, my remote stopped working to my 2004 rx8. it's the fob that's separate from the key. Put new batteries in it, still nothing. I had problems with it off and on for the last couple months, sometimes having to get closer to the car for it to work, thus me thinking it's the batt.
Now with new batteries, not working. Wondering who has a fix for this short of buying a new one.'
Tx!
Old Jan 7, 2012 | 06:13 PM
Grace_Excel's Avatar
Charles Bundy
It's time for you to get a switch blade key. I came across the same problem as my FOB ran out of battery. Replaced it with a new battery and for some reason the program in the FOB stopped working. I searched and found out that you could use the Switch Blade key with our 2004 RX-8.
Originally Posted by Grace_Excel
Yes, you only need one working key to program the FOB and make sure you buy the right Model.
Old:
Visteon Model: 41848
FCC ID: KPU41805
IC: 4238A-12076
What you need to buy:
Visteon Model: 41525
FCC ID: KPU41788
IC: 4238A-41525
Originally Posted by phey_05
Just got my switchblade today...
totally works on my 2004 MT...
unit i bough on ebay:
FCC ID: KPU41788
IC : 4238A-41525
VISTEON 41525
i just followed this instructions: (few modification to be more NOOB friendly like me)
Remote Programming
• Ensure that all doors, trunk, and hood are closed,
• open the driver’s door
Carry out the operation below within 24 seconds:
Insert key
• Turn ignition to the run position and off, 3 times (on-off, on-off, on-off)
• Leave key in ignition (off position, not lock or on)
• Push door switch, 3 times (The door switch is the little rubber one on the jamb of the rear door next to your elbow when sitting in the driver’s seat, which controls the interior lights.)
• Car will lock, then unlock automatically after pressing the door switch 3 times
While the car is in unlock mode, Push 'Lock' on your newly acquired remote 2 times, (some suggest unlock, so try both)
• You will notice after pressing the Lock button on your remote, Car will lock, then unlock automatically again.
• Take out you key on the ignition and test your remote.
If it doesn't work, wait for a minute or so and repeat the procedure
NOTE: I DONT HAVE any existing remote. so no need to have an existing remote to do this procedure
cliffkemp
Dec 24, 2024 10:48 AM
crimson809
Aug 14, 2016 10:03 PM
Hdez Mex
Sep 24, 2015 02:47 AM
ErwinN
Sep 23, 2015 09:29 PM
