DIY: Code your own key / remote
Old Mar 11, 2011 | 04:06 PM
  #376
Grace_Excel's Avatar
Charles Bundy
Originally Posted by klzebob
my question is, could i go buy another switch blade after that and reprogram the new 3rd switchblade using the mazda newly reprogrammed key and my old 04 key?
I believe you could as long as you have two working keys (your '04 key and the newly programmed switch blade). If you look back a few pages, you will see the instructions how to program your third one.
Old Mar 11, 2011 | 04:44 PM
  #377
klzebob's Avatar
sounds good, i've been reading over the procedure and wasn't sure about the 04 key being able to be used after switching over the the 05+ switchblades
i guess i just have to go to the dealer to get robbed for a key reprogram
Old Mar 11, 2011 | 08:30 PM
  #378
Charles Bundy
Try it first before you spend and have buyer's-remorse later.
Old Mar 12, 2011 | 04:03 PM
  #379
the stig's Avatar
I like roast duck
So i just recently bought an 04 used from someone, and they only gave me 1 key and 1 remote
i've been wanting to switch out to the switchblade one and in order for me to do so I would have to go to the dealer to get it reprogrammed with their machine
i've been hearing that the ecu picks up a different frequency and all that stuff
all the mazda dealerships around here in canada charge 50$ to program a key and 50$ to program the fob which is disgusting
$50 is cheaper than what they offered me. my local dealer quote me $360 after tax for the key it self and they cut it for "free" and program the key cost $130. and they said they need a $10k computer program to do it. i said to them that can't you do it yourself? because i remember i read it on the forum before. and he gonna be like well if you can buy a $10k program that we have then sure. what an ******
Old Mar 14, 2011 | 09:14 AM
  #380
mycarRX8's Avatar
Hello,
When I bought my Mazda RX8 (2005) the dealer gave me only one key (excluding the remote fob) and the spare key got lost by courier/post
Now I have a remote from a 2004 mazda RX8. Will I be able to re program in to my car?
Pleae advise
Kind Regards
Old Mar 15, 2011 | 01:28 AM
  #381
Charles Bundy
Do you have this 2004 remote?
Visteon Model: 41848
FCC ID: KPU41805
IC: 4238A-12076
I've never heard of anyone retro-grading; however, your only key will allow you to Program the remote.
Old Apr 2, 2011 | 02:00 PM
  #382
peanutbuddy7's Avatar
Peanutbuddy
Just did this and definitely DO NOT need ANY existing fob's to program the new one. Great DIY thanks to all.
Old Apr 9, 2011 | 07:32 PM
  #383
RxCarter's Avatar
Originally Posted by magixpuma
just coded my own 05 key thanks guys. the transmitter was the hardest part but ill give good instructions right here.
1 sit in car
2 open driver door
3 put the key in move it
to lock to on
to lock to on
to lock to on
theres a small button in the door jam with a rubber stopper on it press it 3 times
now check that the door buttons still work and lock and unlock the doors.
then press any button on your key fob twice. now be patient cuz it takes like 5 seconds for it to first work.
MAKE SURE YOU DO THIS ALL QUICKLY!!!! 30 secs and under.
Hmm tried this and after pushing the door button the car locks and unlocks its self. Then push the button twice on key fob and push unlock button on the door...NOTHING so i close the door and car locks and unlocks its self twice. Hmmm is this not for a 2004?
Old Apr 9, 2011 | 08:47 PM
  #384
ShellDude's Avatar
weeeeeeeeee
sigh
Old Apr 30, 2011 | 06:23 PM
  #385
ace10134's Avatar
Works fine for 2004's, your remote is probably dead. Mine died completely, so I bought a 2005 Switchblade key from eBay for $40, and programmed it. That includes the blank key and the remote, awesome deal! Then just get the key cut at a locksmith, program it yourself using the instructions in the thread.
The instructions for programming a remote FOB works perfectly for a 2004.
Old May 15, 2011 | 07:54 PM
  #386
rotary's dream's Avatar
zumzumzumzum.....
I got my car from last owner, but the remote doesnot work, even I changed new battery, what should I do? I got only 1 remote from the last owner, 1 key, and don't know how to do
Old May 16, 2011 | 09:38 AM
  #387
ace10134's Avatar
Is your Mazda a 2004? If so, buy the 2005 switchblade key. It works perfectly with the 2004 and it is cheaper, and includes the remote and key in one! Ordering them from eBay is usually the nest option. Get a new key, and try to get a 2005 one with the FCC ID of KPU 41788
If you have a different year car, then buy your respective key, and also buy the respective remote if you want the remote.
Now to program them: For the actual key, you will have to go to a special locksmith or to Mazda. The locksmith you go to will need to be able to program transponder keys. You might be able to find one that will do it for $75 or $50. Mazda will charge over $100.
To program the remote, just follow the instructions for programming the remote in the first post of the thread, that will work!
Old May 22, 2011 | 02:58 PM
  #388
Suds488's Avatar
Batmobile
I have 2 remotes but none work. I have replaced the battery but neither of them work. I tried to program but I guess I need one working remote. Is this correct? Is there any way to reprogram them to the car? I have checked everything and the remotes are getting power so the only think I can think of is they lost their ID but this makes not sense.
Old May 23, 2011 | 09:36 AM
  #389
skrubol's Avatar
You do not need a working remote to program another remote. Just either 1 or 2 keys (I forget which, it's in the procedure in the OP.) I think I have heard of remotes just stopping working though, so you may not have any luck there.
Old May 24, 2011 | 01:35 AM
  #390
JeRKy 8 Owner's Avatar
Stuck in a love triangle
My final 04 remote went bad last week (that was my third one)..and replacing the battery didn't fix it.. so I finally broke down and bought one of these coveted flip key remotes after 8 years of using the regular 04 ones. Cost about 50 bucks shipped (eBay)...and programming the new remote was effortless. Just have to get the key cut somewhere tomorrow.
By the way, I hope the paint on the lock/unlock button on these remotes doesn't fade as quickly as the paint on the old remotes did. That was something that really annoyed me about the old ones.
Old May 24, 2011 | 10:38 AM
  #391
Hey I've got a question about programming the new key (not the remote) and I read through every page on this thread and noticed this was never asked after 7 years which is surprising.
I've got two old keys to my 8 plus this new one, but I haven't been able to find one of the 2 old keys. Probably in the garage somewhere or something. When performing the new key programming procedure, do I actually need both keys to be present in order to program the new key, or can I do it with just one of the old ones?
Old May 24, 2011 | 11:02 AM
  #392
StealthTL's Avatar
Metatron
Two keys need to be 'recognized' before the ECU will take a third.
Old May 24, 2011 | 06:42 PM
  #393
Damn...so I've got to go find the spare key in order to do this. Oh well..thanks
Old May 28, 2011 | 11:51 PM
  #394
zumzumzumzum.....
The problem is I got only 1 key for this 8, and I need a new key ( with remote), What should I do? Take my car to dealer is the only way?
Old May 29, 2011 | 02:40 AM
  #395
ace10134's Avatar
If you only have 1 key, you have a few options:
  1. Go to the dealer, purchase a new key/remote combo, and have them cut/program it.
  2. Go to the dealer, purchase a new key/remote combo, have them cut/program the key, and then program the remote yourself (if they want to charge you for programming the remote)
  3. Go to the dealer, purchase a new key/remote, then find a locksmith that can "program a transponder key for a 2004 Mazda RX8", and have them cut/program the key. Then program the remote yourself.
  4. Go online, purchase a new key/remote (cheaper), then find a locksmith (just like the step above)
Just call around for locksmiths and ask them if they can program transponder keys. You might be able to find one that will do it for $50. Otherwise, you're looking at over $100 at the dealer for just programming the key.
Old May 30, 2011 | 10:44 AM
  #396
skrubol's Avatar
5. Buy a second normal key from the dealer, then buy a switchblade from the Internet, have it cut somewhere and program the key and remote yourself.
Old Jun 6, 2011 | 05:13 PM
  #397
Jaysus's Avatar
Just went to the dealer and they couldn't program any remotes.
I came back from my deployment and my car hadn't been started at all (wife doesn't love me), so it completely died. Ever since then the remotes haven't worked. The anti-theft system still works and the horn goes off if someone tries to open the door when it is locked. The red blinking key light blinks normally. I can get it into programming mode, but once you need to click the button on the remote, nothing happens. I tried it about 100 times and gave up on it and figured I just needed to get the dealer to do it. He tried it and did exactly what I was doing, which would have pissed me off if he had the "magic touch" or something. They're saying it is electrical issues or something, so I have to take it back in to get it diagnosed for 100 bucks. Cost me $75 to have them tell me they couldn't program any remotes and get a key cut/programmed for "free."
Old Jun 7, 2011 | 08:30 PM
  #398
pegasixi's Avatar
Sorry if I'm asking a very noobish question... (on the bright side I'm not starting a redundant thread!)
I have a 2005 Rx8 with only one key (no remote, no service keys). I'm not too concerned with adding more keys, but I definitely want to add a remote. As far as I can tell from this thread, I only need:
1 key, no pre-existing remote to add a new remote[/B]
2 keys to add a new key
So if I just buy a 05 rx8 remote from ebay, I should be able to program it using the steps mentioned in this thread using my single key?
Old Jun 8, 2011 | 05:03 AM
  #399
Charles Bundy
Yes, you only need one working key to program the FOB and make sure you buy the right Model.
Old:
FCC ID: KPU41805
IC: 4238A-12076
What you need to buy:
Visteon Model: 41525
FCC ID: KPU41788
IC: 4238A-41525
Old Jun 30, 2011 | 11:27 PM
  #400
vX-2's Avatar
I found these numbers on my Keyless Remote Controller Unit (below handglove box)
FE03 67 5DZ A
4A13C
Visteon 41872 43
May I know two things?
1) Can I use switchblade remote?
2) Which one should I get?
It's like this here:
http://cgi.ebay.com/ebaymotors/04-05...Q5fAccessories
And obviously I can't determine which IC that it's compatible with. Any clue?
