New coils, wires, spark plugs and second hand fuel pump P0352, P0351 :scratchhe
Old Dec 27, 2011 | 11:13 PM
RX8_'s Avatar
NZ New coils, wires, spark plugs and second hand fuel pump P0352, P0351 :scratchhe
Can anyone help me understand why I am getting these error codes?
So far I have changed:
New Coils
New Coil Wires
New set of Spark Plugs
2nd hard fuel pump
I am getting P0352, P0351
Please help
Old Dec 28, 2011 | 07:24 AM
Wingznut's Avatar
Go Red Wings!
Is your Check Engine Light currently on? Have you tried erasing said codes, since your repairs?
Old Dec 28, 2011 | 07:43 AM
wcs's Avatar
wcs
no agenda
Are you boosted?
How about a little about your car, like what mods you have?
Old Dec 28, 2011 | 12:00 PM
xexok's Avatar
According to other threads those codes are not even legit. Your scanner may not be working properly with the rx8 for some reason because those codes are not even listed anywhere. Not sure what to tell you about that. https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Are you having any actual issues, or only the codes? Also what ignition wires did you go with?
Old Dec 28, 2011 | 06:50 PM
RX8_'s Avatar
I have swapped the coils around to see if it makes any difference but nope.. I am running Bosch coil wire,
Went for a short drive car seem to be normal although engine is shaking at idle..
The engine light does come on after 2nd start. I have cleared the code from the scanner as well as disconnect battery no difference..
Also getting C0700 code now?? wtf..
Car is running Greddy Turbo (emanage blue)
Catless exhaust system
No other mods.
video below
Old Dec 29, 2011 | 09:49 AM
xexok's Avatar
Like I said maybe try another scanner, because that one may not be communicating properly with your car. That was the general consensus from the thread I linked, but you can check around also.
Old Dec 29, 2011 | 01:58 PM
Brettus's Avatar
Boosted Kiwi
You are running a turbo with Emanagle blue and your only worry is that you are getting Cels ? Lighten up man and be glad you haven't blown your engine ............. Yet .
Old Dec 29, 2011 | 02:26 PM
Tamas's Avatar
Registered Lunatic
I was already waiting for someone pointing to the eManage blue
Old May 8, 2014 | 07:19 PM
JimmyBlack's Avatar
Hybrid Greddy Boosted
Not strictly caused by eMangle, JDM with non-stock coils trigger these codes.
See comments in this thread.
Old Oct 28, 2015 | 04:47 AM
pakura's Avatar
I have stock 2004 rx8.
a week ago, light on check on dashboard.
I checked this by obd scanner 2 and many other scanner and they show P0351. I tested Coils, Coil Wires and Spark Plugs there are ok but Spark Plugs have some dammage. today I just changed Spark Plugs with NGK Laser Iridium Spark Plugs RE7CL RE9BT
and now obd scanner showed me P0352, P0351.
so what problem is it?
sorry for my bad english.
Old Oct 28, 2015 | 09:32 AM
RX8Soldier's Avatar
Time for boost...
read this thread https://www.rx8club.com/rx-8-discuss...51-help-95222/
I presume that you have a JDM car? It sounds like this is an issue with JDM ecu's
Old Oct 31, 2015 | 07:42 AM
Fk444's Avatar
Hey everyone..
I installed BHR coils and wires in my 8 yesterday. They are working really well but after a while an engine check light came on which won't go. Even after resetting it reappears after a while. I scanned it and the code says "Status ff (above maximum threshold)"
It's a JDM model.
Old Oct 31, 2015 | 10:32 AM
Fk444's Avatar
Is Cobb access port of any help here.
And btw let me clear it up to everyone. BHR doesn't fail to impress. Surpassed my expectation and I'm in love with it. I don't think I'll prefer any ignition kit over it.
Old Nov 7, 2015 | 06:20 AM
pakura's Avatar
On the dashboards appeared checks lights:P0351 , P0352. Because of this I've changed ignition coil, ignition coil wire and spark plug but check is still appairs.
After start on rpm 1000 - 2000 engine has strange voise.
After start while engine is cold exhaust smoke is strangely much and white.
Check out engine sound while music starts in my first video.
In second video after release acceleration pedal you can hear strange sound and smoke is also too much.
Also car has slightly less power.
Please help me..
Thanks in advance.
Video1:
Video2:
Old Nov 8, 2015 | 11:09 PM
ouimetnick's Avatar
Zoom Zoom
Create your own thread! That way people will see it and help you.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
PotatoCannon
Sep 6, 2015 11:48 AM
Shinka84
Aug 19, 2015 04:55 PM
GracefulShanks
Aug 18, 2015 11:40 AM
