Esmeril Turbo Issue
Old Dec 23, 2011 | 03:26 PM
faith&firepower's Avatar
My Other car's A Stryker
Esmeril Turbo Issue
Hey everyone,
I have my Esmeril kit installed and we are hammering out the detail for tuning. Jeff (MazdaManiac) and I have using the COBB I bought from him a few years back. Our Issue is with the car going full lean at 3k RPM.
We swapped the middle injectors for 1000cc and took those yellows and put them in place of the reds. I also installed the 300lph fuel pump that came with the kit. The car idles amazingly well, but as soon as I get to 3-3500prm it wants to shut down.
We took the fuel pump out today and checked everything, same with checking the injector setup and wiring. We just cant figure this out. I can only think that the fuel pump is our issue....
PLEASE HELP!
Old Dec 23, 2011 | 03:56 PM
Do you have a factory assembly with a factory pump in it to try out? I could lend you one if you need it.
Old Dec 23, 2011 | 04:30 PM
Turblown's Avatar
Boostin'
There have been reports of issues with that pump on Rx-8s...
Does it do this while free revving or just under load? Could be a lot of stuff...
Old Dec 23, 2011 | 05:10 PM
Luckycat's Avatar
Originally Posted by faith&firepower
Hey everyone,
PLEASE HELP!
Which fuel pump do you have? The walbro or the aero motive? Mine did a similar thing at 12 psi with the old walbro. Swap out with the aero motive 340 LPG pump but has not test that pump yet.
Old Dec 23, 2011 | 07:29 PM
olddragger's Avatar
fuel pressure?
o2 sensor ok? ( open versus closed loop)?
Is Jeff remote tuning or live tuning?
Huge vacuum leak through the ssv?
If jeff is on the scene--then I certainly dont know anymore than he does.
Old Dec 23, 2011 | 08:59 PM
Brettus's Avatar
Boosted Kiwi
go back to stock injector setup and see what happens
Old Dec 23, 2011 | 09:09 PM
The fuel pump should be easy to diagnose......measure the FP.......fuel pressure is fuel pressure really you either have it and it is stable...or it isn't
You sure you have the injectors hooked up properly?
Old Dec 23, 2011 | 09:58 PM
Sounds to me like the PCM is in limp mode. It does the same thing when on the rev limiter.
Old Dec 23, 2011 | 10:08 PM
Easy to check too, with the key on - engine off and the throttle pushed wide open look at the throttle body blade and see if it is in the wide open position
Old Dec 26, 2011 | 02:12 PM
Turblown "There have been reports of issues with that pump on Rx-8s...
Does it do this while free revving or just under load? Could be a lot of stuff..."
-It has been doing this since the first start of the motor. It does it both free rev and under load.
TeamRX8 & Charles R. Hill-I'll have to look at that valve, but the PCM should be ok at this point. This problem has been going on since the very first start with the kit on. I think we will try the old fuel pump, as its easier to swap out than trying to test for fuel pressure here at my shop.
Old Dec 26, 2011 | 02:21 PM
Nobody should ever install a turbo kit without some type of fuel pressure indicator/alarm.
Thre are other causes for limp mode than just the OMP.
Old Dec 26, 2011 | 04:18 PM
laythor's Avatar
I zoom therefore I am.
^+1 we might not agree on many things but I'm 100 percent in agreement with you on this.
Old Dec 28, 2011 | 05:10 AM
papadoo's Avatar
I have same issue went we install the Esmerilracing kit and Dave from speed1 order a new fuel pump issue resolve
Old Dec 28, 2011 | 09:19 AM
olddragger's Avatar
Team is right on this--it might save your engine. Since you cant watch gauges all the time, get one with a warning light and recall. Fuel systems and ignitions system are critical for FI rotary.
Old Jan 20, 2012 | 06:44 PM
Update.
We swapped the fuel pump and it seemed to be running a lot better, then once it warmed up it started doing the same thing again. Out of sheer guess work, we unhooked the MAF and started it up. We only did this for a quick trial, but the engine didn't bog down and revved freely through the entire range.
With this being a blow through set up, what options do I have left? Should I try and order a new MAF? Let MM/Jeff know and have him advise me?? Maybe he will read this soon....
Thanks for any ideas.
Old Jan 20, 2012 | 09:30 PM
Brettus's Avatar
Boosted Kiwi
Do you have a honeycomb maf straightener in place ?
Old Jan 20, 2012 | 09:45 PM
Congratulations on finally getting something right
Old Jan 21, 2012 | 09:22 AM
olddragger's Avatar
while the car is idling tap the top of the maf sensor and see if the idle changes--if it does thats a symptom of a bad sensor.
also check the harness/wiring.
It would be strange for the sensor to go bad exactly when the kit is installed.
Old Mar 5, 2012 | 02:05 PM
We installed a new MAF, same issues.....
Old Mar 5, 2012 | 02:45 PM
Chris's Avatar
Turbo Member
have you changed the plugs recently? I know when I bogged on fuel trims the result was fowled plugs. I would check them for sure. I had the same symptoms that you are when I had fowled plugs
Old Mar 5, 2012 | 03:10 PM
I have a new set of colder plug, but I was waiting to break in the car a bit before I put them in.
From what MM told me, the STFT are going to 0% at the 3-4k rpm range.
Old Mar 5, 2012 | 08:31 PM
MazdaManiac's Avatar
I've got a session tomorrow afternoon and another Thursday morning.
Jump on if you can.
Old Mar 7, 2012 | 10:31 AM
OK, I'll be on tomorrow
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
iwannarun
Sep 6, 2015 01:37 PM
MIGhunter
Sep 5, 2015 07:21 PM
