New Battery or something else?
Old Dec 16, 2011 | 06:39 PM
iErc's Avatar
Eric
hey all, I'm a relatively new 8 owner so bear with me.
My eight's been having a hard time starting up while warm (and even cold now that the temperature is dropping)
Say I fill up at the gas station, it takes forever to turn over. I was wondering if this was a battery, starter, or possible flooding issue.
Here's a video of exactly what's happening. Thanks in advance.
http://youtu.be/VR11iS_hRc8
(edit)
Car Info:
2004 Automatic, 57k miles, all stock, just had it in the shop last month to replace the fuel pump.
(EDIT 01.15.12)
ok, so I changed out the spark plugs, coils and dropped an optima redtop in there (hooray christmas bonus).
It helped a lot!! I'm pretty sure I've got the old starter, so once I make sure it's the old one I'll order the new one.
Thanks for all your help, these forums are a lifesaver.
http://youtu.be/uBfrmnU3_ys
Old Dec 16, 2011 | 06:44 PM
jasonrxeight's Avatar
new plugs and new coil. if that doesnt fix the problem, compression test then new engine.
monchie's Avatar
I HATE SPEEDBUMPS!
Info about your car...year, mileage, mods?
Old Dec 16, 2011 | 06:56 PM
iErc's Avatar
Eric
2004 automatic, 57k miles, all stock, just had it at the shop about a month ago to replace the fuel pump.
Old Dec 16, 2011 | 07:17 PM
xexok's Avatar
When was the last time you changed the plugs and coils?
Also if you have a multi meter you can check the battery voltage, that would help to know if it is any good or not. I think autozone/checkers/advance auto also test the battery and alternator for free.
Old Dec 16, 2011 | 07:37 PM
iErc's Avatar
Eric
Bought the car in may, haven't changed them yet.
Old Dec 16, 2011 | 08:57 PM
tonik's Avatar
It sounds like you had the old starter...
Auto Orig : N3Z2-18-400
Updated : N3H2 , N3H2-18-400R0B
Old Dec 16, 2011 | 09:25 PM
iErc's Avatar
Eric
Alright, I ordered new plugs and coils. Hopefully that fixes the problem.
thanks for your help, guys.
Old Dec 17, 2011 | 02:14 AM
Wingznut's Avatar
Go Red Wings!
Nice job posting the video... That kind of thing helps so much when offering troubleshooting help.
Your battery sounds just fine. But tonik makes a great point, you should check to see if you have the updated starter.
Old Dec 17, 2011 | 10:16 AM
The root of the problem is obvious
https://www.rx8club.com/rx-8-discussion-3/confused-about-what-belongs-forum-47393/
Old Jan 12, 2012 | 06:44 PM
iErc's Avatar
Eric
Is Fixed
Old Jan 12, 2012 | 08:36 PM
Dont need to get the starter from mazda
U can get the faster starter as long as u buy one thats for 2007+ rx8. I bought one from beck and arlney, cost like 240 comes with long warranty. Havent have the time to install it yet but the starter comes with papers about various of test they did on it. Not bad. Keep in mind tho some company like bosch will sell the old slow starter to u no matter which year u pick. So make sure its a 2.0kw starter. Not 1.4kw.
Old Jan 13, 2012 | 12:45 AM
iErc's Avatar
Eric
Thanks for the heads up, would it be a bad idea to grab one out of newer model eight from a junkyard?
Old Jan 13, 2012 | 05:35 PM
04RX8man's Avatar
Rotary Powered Countryboy
Old starters FTW still have mine in there!
Old Jan 13, 2012 | 06:47 PM
Silver_Surfer's Avatar
I4NI
I vote somthing else
Old Feb 21, 2012 | 10:28 PM
iErc's Avatar
Eric
got a new engine
Ok, so it ended up being low compression with meant a new engine. Thankfully I was still under warranty.
Here's a link to the new startups
http://youtu.be/VPD3hZmQlus
and here's the before and after
http://youtu.be/hoTEDjU0Fc4
thanks again for all your help
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
