best handling rx8
Old Nov 10, 2011 | 01:50 AM
edoloman24's Avatar
best handling rx8
i have a stock 2004 rx8 and i wanna know what i should do to make it even better at handling, and what i should do to make it go around a track way faster, like brakes and stuff like that. i know im not gnna be able to afford more speed so i might as well do this thanks
Old Nov 10, 2011 | 02:27 AM
ekliptik's Avatar
if u need to ask these questions, than the car can already out handle the driver in stock form.
Old Nov 10, 2011 | 02:43 AM
LifeAfterRx8's Avatar
I would start with tires.
Then work on suspension.
I upgraded to Konis/Tein-S springs and it was a major improvement above stock.
Then upgrading swaybars would probably help.
Installing a front strut bar, possibly rear.
The stock brakes are actually pretty good, if you replace the pads + brakelines you should be okay.
Old Nov 10, 2011 | 09:52 AM
c0ldf1ame's Avatar
stock car has plenty of capabilities around the track, get some better brake pads, flush the brake fluid with one that's rated at a higher boiling temp, spend the rest of the money on track days and a helmet, learn on crappy tires and upgrade to better ones once you wear these out.
Old Nov 10, 2011 | 10:37 AM
Wingznut's Avatar
Go Red Wings!
High performance driving classes are by far the best way "make it go around a track way faster".
Old Nov 10, 2011 | 10:53 AM
bse50's Avatar
#50
Upgrading the suspension may end up being just as expensive as adding some power lol.
HPDEs and driving classes!
Old Nov 10, 2011 | 12:30 PM
TopGear8's Avatar
mkuhnracing.com
Making it fast around the track would be the drivers job, not the cars...
Old Nov 12, 2011 | 12:36 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Stock form is already good enough for the track.
Old Nov 12, 2011 | 11:52 AM
alnielsen's Avatar
This is probably the best advice if we are sticking to the car. On a track day, you aren't going for best times. It's about improving your on-track capabilities. The stock suspension is more than adequate.
With the wrong combination of suspension mods, you can rune your handling.
Old Nov 12, 2011 | 12:11 PM
jareclese's Avatar
jareclese
Vredestein Ultrac Sessanta tires NUFF SAID! i always kiss them goonight. great handling and they wear pretty slowly by max performance tire standards. they have really good wet grip too, beats the crap out of toyo. but i'm also with coldf1ame and alnielsen , boost up your skillz its a sports car from birth! get good tires and brake pads and keep the car well maintained.
Old Nov 12, 2011 | 12:16 PM
Easy_E1's Avatar
Yep.
ouimetnick
25
Sep 14, 2023 01:44 PM
arjunmshah
Aug 6, 2015 10:56 AM
MolecularConcept
Aug 1, 2015 03:15 PM
vetteor8
Jul 25, 2015 11:43 AM
