Tires to bulky on wheels??
Old Sep 27, 2011 | 12:58 PM
EvisuMan's Avatar
*Ice_King*
I bought some XXR 527 18x9.75 and one of my friends told me that I should get some 225/45 18 tires for the wheels. When my tires came in I took them to a tire shop for a stretch. Heres how they look like when they stretched the tire on the wheel.
Size:  99.2 KB Is that supposed to look like that
When they mounted them on my car it was rubbing on the fender. Name:  2011-09-26180618.jpg
My question is, what is the proper size tires for these wheels??? Heres a few more pics..
Old Sep 27, 2011 | 01:00 PM
RX8Soldier's Avatar
Time for boost...
you should spend some time reading the "Will it fit" sticky
tiltmode43's Avatar
OMGITM!
That sized tire should stretch a fair bit on that sized wheel. Perhaps this is what you meant by "bulky"?
What was the offset of the wheels?
edit: Just saw that photo of the wheel only that didn't load the first time. This sized tire is somewhat narrow for this sized wheel, hence the slight stretch.
Old Sep 27, 2011 | 01:51 PM
Well, your car looks pretty damn low on stock wheels. What offset are these?
Old Sep 27, 2011 | 02:07 PM
EvisuMan's Avatar
*Ice_King*
The offset on the wheels are +20
and yea i dropped it about 4-5 inches from stock height lol
Old Sep 27, 2011 | 02:12 PM
TX
Well duh. Are the springs cut? Looks like it.
Old Sep 27, 2011 | 02:20 PM
EvisuMan's Avatar
*Ice_King*
Nope Im using tanabe coilovers.
Old Sep 27, 2011 | 02:25 PM
Okay well then those should be able to fit. One of our local guys was on tanabe's running 18 x 10 +18 running 265/35-18's. Time to get the wrenches out and start adjusting.
Old Sep 27, 2011 | 02:30 PM
EvisuMan's Avatar
*Ice_King*
Lol true that, I was thinking of rolling the fenders and adding some spacers. What do you think about that?
Old Sep 27, 2011 | 02:35 PM
TX
Adding spacers? No dude. Rolling fenders? Yes you must.
Old Sep 27, 2011 | 02:41 PM
EvisuMan's Avatar
*Ice_King*
Ok cool, I wasnt sure if I should add spacers lol what about the corner blinkers, am I going to have to take them off or can I leave them on prior to rolling the fenders.
Old Sep 27, 2011 | 02:52 PM
That is all determined on how you get the car stanced. Some people retain them, some do not. There is a lot of experience and know how that goes into it when you start getting that aggressive and low. Maybe some of the wheels spec pros with chime in to help you.
Old Sep 27, 2011 | 03:00 PM
EvisuMan's Avatar
*Ice_King*
Yea that's true. I'm trying to get that aggressive look. But just need help getting there lol
Old Sep 27, 2011 | 03:26 PM
RX8inSTL's Avatar
Adam
Probably should have gotten 235/40s or 225/40s.
And kinda off topic but I dont think thats a 4 inch drop. Probably closer to 3
Old Sep 27, 2011 | 03:56 PM
EvisuMan's Avatar
*Ice_King*
My two front tires are 225/40 lol
Old Sep 27, 2011 | 03:58 PM
If the tires are rubbing on the outside...spacers will make it worse
Old Sep 27, 2011 | 03:59 PM
wrightcomputing's Avatar
Made in England
I think you are going to have to either give up height of give up wheel size.
Old Sep 27, 2011 | 04:39 PM
EvisuMan's Avatar
*Ice_King*
that doesnt make sense because Ive seen a couple of rx8's that have 18x10.5, best thing i can do is roll my fenders.
Old Sep 27, 2011 | 04:47 PM
Made in England
Rolling the fenders is only going to give you a little bit of extra room behind the fender. The second photo looks like the tire is out past the outside edge of the fender so rolling wont help.
I would alter your alignment and give as much -ve camber as possible this will pull the tops of the wheels inwards and may give you more room.
I did my own camber in about an hour, this is the thread I started and got loads of help on how to do it.
https://www.rx8club.com/rx-8-racing-25/setting-camber-my-rx8-211698/
Old Sep 27, 2011 | 05:00 PM
Atilla's Avatar
I am THAT guy
^you're forgetting a very important component in that statement.
OFFSET.
Offset will determine how easy or difficult fitting a wheel and tire will be.
18x10.5 +50offset or something will pretty much be cake compared to fitting 18x10.5 +5offset.
For what you're trying to achieve you should be able to get away with a good fender roll and a good alignment. The tire specs are a bit tall though but if the tires are already purchased then you really can't do much.
Old Sep 27, 2011 | 05:14 PM
EvisuMan's Avatar
*Ice_King*
OFFSET.
yea thats true, i totally forgot about offeset lol
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
fireishot34
Sep 5, 2015 06:45 PM
20b-3rotor
Sep 2, 2015 08:54 AM
