best 0-60 times?
Old Mar 1, 2004 | 08:19 PM
vliberto's Avatar
best 0-60 times?
i was wondering what you guys have run... indicate whether stock or modded.
i got a 6.4 0-60 with a 2.25 60ft timei only did 3 runs, and even that best time i couldn't shift into second as quick as i wanted to b/c of those darned syncros
and what are the best shift points for the 8?
Old Mar 1, 2004 | 09:05 PM
neit_jnf's Avatar
Right before fuel cut, aprox 9300-9400
Old Mar 2, 2004 | 01:22 AM
Murray16's Avatar
Wannabe Guru
I posted this somewhere before but I'll go ahead and say it again...
In a magazine of road and track review of a porduction RX-8, under the special notes they stated that best launches were performed when disengaging the clutch at 7000 rpm.
I'll post a quote and backup my info with issue number and all that...
I don't know if I'd want to be putting that much wearing on the clutch though... I mean... 7000rpm! crazy!
Old Mar 2, 2004 | 03:24 AM
bubble's Avatar
How did you measure your 0 to 60?
Old Mar 2, 2004 | 08:16 AM
Velocity-8's Avatar
Whuumpha!!
The magazines get the best 0-60 by doing things most of us wouldn't do to our own cars.
Old Mar 2, 2004 | 03:06 PM
Murray16's Avatar
Wannabe Guru
obviously..
i cant replace a cltuch every 3 months...
Old Mar 2, 2004 | 03:19 PM
Winning_BlueRX8's Avatar
Limecat's High Priest
I've dropped the clutch a couple times at about 4000-6000 RPMs. I Dropped it at about 7000 once and got nothing but wheelspin. I guess there is a sweet spot to hit. I don't have an accurate way to measure 0-60, so I can't really say how long it took. It didn't take long though, I'd imagine roughly 6 seconds. Then again I don't drag often, so I'm inexperienced.
Old Mar 2, 2004 | 05:56 PM
TM45's Avatar
My best is 6.95 seconds as measured by a G-timer device.
I did not rev the engine at takeoff--normal start. No wheel spin. DSC off.
The car lags badly at first without wheelspin and doesn't start to pull hard until revs hit 5000 or so. I was pretty impressed that it still got under 7 seconds under those conditions.
Old Mar 2, 2004 | 06:09 PM
Velocity-8's Avatar
Whuumpha!!
obviously..
Or do what I did in my SAAB 9-3... I shattered the hardened steel half shafts while doing a 6Krpm burnout...in reverse!
uZu
Dec 30, 2015 12:35 PM
tigg.z
Aug 26, 2015 09:51 PM
GrAfiX
Aug 24, 2015 08:08 AM
arjunmshah
Aug 6, 2015 10:56 AM
dbarber
Jul 25, 2015 01:34 PM
