Jon316G
06-26-2011, 05:31 PM
Appears that we needed a DIY for removing the alternator because some feel that you need to remove the alternator bracket.
It would make it easier, but isn't necessary.
1) Disconnect and remove battery along with the upper battery tray to gain some room (and to prevent electrocution).
The pic below I have the whole battery box removed, but its not required (I was working on something else too).
173691
2) Disconnect the harness to the alternator.
173692
3) Open covers to expose the wire and nut, then remove nut and wire from housing.
173693
4) Completely remove tension bolt and the piece that runs through the alternator bracket (piece the tension bolt threads through).
173694
5) Remove bolt that secures alternator to the engine.
173695
173691
173692
173693
173694
173695
