CarPC with OEM Nav Hood W/O Wiring Harness
Old Apr 22, 2011 | 07:57 AM
Dbl helix's Avatar
I bought the OEM Nav hood / screen for a Carpc install I found the wiring diagram (below) I hooked it up with just those wires but the Open / Tilt wouldn't make the screen move is that all that is needed to wire up for open / close to work? If so I guess mine is bad. Also the screen does come on but just with a black image with white lines running from bottem right to top left. Do I need a video sorce before it will open?
Attached Thumbnails CarPC with OEM Nav Hood W/O Wiring Harness-lcdpinout.jpg
Old Apr 22, 2011 | 08:23 AM
Dbl helix's Avatar
Nevermind that is the right wiring I was looking at the motor a little more closely and relized that it had a piece of glass stuck in the gears : / I guess thats what happens when you get one from a junk yard that had a tree fall on the car.
Old Oct 22, 2011 | 11:33 PM
https://www.rx8club.com/series-i-do-yourself-forum-73/what-belongs-diy-forum-163653/
drebbrnator
Dec 27, 2018 07:02 PM
fireishot34
Sep 11, 2015 12:54 PM
RXeckless
Aug 16, 2015 12:51 PM
MolecularConcept
Aug 1, 2015 03:15 PM
