Hotter TSB plugs + CZ Stage 1?
Old Feb 14, 2004 | 10:17 AM
racerdave's Avatar
F125er/Future RX-8er
Has anyone tested this combo?
Just wondering if these plugs were installed by the dealer, and CZ Stage 1 was added afterward... what would the effects be?
Old Feb 14, 2004 | 10:44 AM
RX-8 friend's Avatar
Canzoomer has the Stage 2 prototype module installed in his car. It has all the features of Stage 1 plus timing changes. Still not -at- stage 2. About half way there. Telling you this just for reference. On thursday he had service done at Mazda (with the module in and on). Part of the service was installation of the hot plugs. Works fine. We also confirmed the dealer OBDII will find the module in there if it's on. It senses MAF errors.
Thought everyone should know. He has a good relationship with this dealer, so they were interrested as well about the module.
Old Feb 14, 2004 | 11:28 AM
racerdave's Avatar
Thanks for the plug info.
Can the dealer also detect Stage 1?
Old Feb 14, 2004 | 04:49 PM
Yes. The MAF part is the same electronics. If you switch it off, it should be undetectible. Oh, BTW, he also had all the updates put into the PCM (with the box connected and turned on). So that isn't a problem.
WranglerFan
Aug 21, 2022 01:29 PM
WranglerFan
May 31, 2022 07:51 AM
tallestmexican
May 1, 2018 07:22 AM
Vedivan1
Sep 18, 2015 12:39 PM
DVerdeyen
Sep 13, 2015 11:19 AM
