engine very hot
Old Aug 8, 2010 | 08:31 AM
VROOM's Avatar
KS engine very hot
Hi, just needed some assistance, none of my lights are coming on, so there's no fault showing! However when driving around even for small distances and switching the engine off, it is very hot, even the plastic covers covering the engine are very hot.
Any reasons why?
Old Aug 8, 2010 | 09:00 AM
RotaryTherapy's Avatar
check your muffler bearings ... lol
Old Aug 9, 2010 | 05:32 AM
VROOM's Avatar
UK hot engine
Hi, what you refering to 'muffler bearings'?
cheers
Old Aug 9, 2010 | 05:55 AM
Flashwing's Avatar
3-wheeler
Any reasons why?
Yep, it gets hot under there...the internal combustion chamber sees temperatures in the thousands of degrees.
Old Aug 9, 2010 | 07:09 AM
Rote8's Avatar
Constipated kitty?
Old Aug 9, 2010 | 07:13 AM
terch1's Avatar
I think this is normal with Summertime temperatures. Mine is always very hot as well.
Old Aug 9, 2010 | 09:39 AM
DarkBrew's Avatar
Extraordinary Engineering
Put some gauges on your car.
See http://www.racingbeat.com/Mazda-Perf...rtNumber=11816 for example.
Old Aug 9, 2010 | 11:15 AM
Spin9k's Avatar
Momentum Keeps Me Going
Get an infrared pyrometer...measure your underhood temps. If it's much hotter than 212-250 you may be on to something, but otherwise you do realize that internal combustion creates heat and in that process the gases produced can be as hot as 3000 degres F?
vapor2
Nov 3, 2020 03:38 PM
learningdriver
Aug 8, 2015 06:55 AM
dbarber
Jul 25, 2015 01:34 PM
Belalnabi
Jul 22, 2015 04:50 PM
