MM tune with CAT
Old Jul 19, 2010 | 07:00 PM
rx8convert22's Avatar
Question MM tune with CAT
I just took the plunge and bought an AP due to the discontinuation. I wanted to see if other people have run a stock cat or RP supercat with a MM tune? I am buying a midpipe for when I go on the track, but don't think I want to deal with fumes on a daily basis. I was thinking of either keeping my stock cat or buying a RP supercat for daily driving. Before I did this though I wanted to see if people had experience of cat life with a MM tune. Thanks.
Old Jul 27, 2010 | 02:48 PM
stinksause's Avatar
The Stink w.o The Sause
somewhere here I have read that supercats actually flow LESS than normal cats ...
I can't speak from experience, but the tune should help you regardless. You may want to make sure that he tunes your car catless for the best results though
Old Jul 27, 2010 | 02:50 PM
MM tune can getmost of the smell away. From the outside, you can tell but very little.
Don't know what the smell with MM tune is like in the cabin with midpipe.
Old Jul 27, 2010 | 02:51 PM
I have the RP cat and it's a pretty good item when paired with MM's tuning.
My last RP lasted about 11,000 miles but it's demise was caused by the ginormous speed bump at MNAO's headquarters. (I put a nice big dent in the cat which most likely broke the cat material)
I had RP repair the cat for me last year and so far it's holding up quite nicely despite the leaner AFR's.
Old Jul 27, 2010 | 04:44 PM
stinksause's Avatar
how lean?
Old Jul 27, 2010 | 04:49 PM
well, on OEM maps I was EASILY pegging the wideband at 11 AFR at WOT around 4k.
I'm closer to 13's at this point. Probably somewhere in the 12.8 - 13.2 at wot.
Old Jul 28, 2010 | 11:48 AM
stinksause's Avatar
Are you NA? That's actually at tiny bit richer than you want to be for NA.
Isn't 14.7 best for CAT?
Old Jul 28, 2010 | 11:49 AM
alnielsen's Avatar
The ecu is tuned to run a bit rich to make the cat last longer. 14.7 makes the exhaust temps to hot for cat longevity.
Old Jul 28, 2010 | 12:00 PM
paulmasoner's Avatar
Asshole for hire
Originally Posted by Jedi54
well, on OEM maps I was EASILY pegging the wideband at 11 AFR at WOT around 4k.I'm closer to 13's at this point. Probably somewhere in the 12.8 - 13.2 at wot.
IIRC from when i looked at the tables on OEM map, ~30% or more of the total range had a target AFR well below 11. i think there were places where the target value was in the low 9's
Old Jul 28, 2010 | 12:13 PM
^^ I agree but without an aftermarket gauge, all I see on my graphs is 11.
I'm pretty sure it was well below that as you mentioned.
Old Jul 28, 2010 | 01:24 PM
stinksause's Avatar
I think that's the rich limit of the stock wideband as far as reporting goes ....
Old Jul 28, 2010 | 01:31 PM
correct.
till I decide to go for max powah, the stock wideband will have to do.
Hunterkelley24
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
Danield97
Sep 30, 2015 05:59 PM
XianUnix
Sep 29, 2015 03:48 PM
