throttle issues
Old Jul 7, 2010 | 09:19 PM
silverkillrx8's Avatar
throttle issues
so ive been having this problem latley with my throttle. well it think it is at least... when im driving the yellow traction control light flashes and i cant accelerate even if my foot is on the gas now if i let go and accelerate again it works but will do the same thing again but this only happens like once a week which is still too much any ideas on what it could be??
Old Jul 7, 2010 | 09:39 PM
Jon316G's Avatar
Grasshopper
Troubleshooting this can be difficult if it only occurs weekly.
Here are a couple easy things I would start with:
1) Reset the PCM- Disconnect the battery for at least 10min.
Cars can be like Windows... just needs a reboot
2) Clean the TB valve- Use Carb Cleaner and a shop rag to wipe around the housing and valve.
I like to remove the 4 bolts to separate the TB from the UIM to clean all around (no need to remove the coolant lines).
I wouldn't think its the APPS (Accelerator Pedal Positioning Sensor) since it takes so long to reproduce the symptom.
And it doesn't sound like a "Limp Mode" if you're able to let off the gas and accelerate without problems.
But lets start with the easy stuff first and go from there.
Old Jul 7, 2010 | 09:49 PM
yea it happened before i got my new motor and i thought it would have gone away but it started up again will try that tomorrow and see how it goes
Old Jul 7, 2010 | 10:46 PM
ASH8's Avatar
Super Moderator
There have been a few members with Traction Control Lights flashing lately....???MMmm
Although I don't have the answers, I am thinking of a few issues that may or may not help.
As we know each wheel has an ABS sensor for Brakes, now this sensor must also register wheel spin or loss of traction from a particular wheel to the PCM/ Stability Control (DSC)...Am I correct here Jon???...don't know what other sensor there is for Wheel Traction???
Also a YAW rate Sensor (box) under the Rear Middle Console .
Had a quick look in EPC and can't see other parts related to Traction Control.
I am wondering if Heat (you guys are having a very Hot Summer) has anything to do with this??.
I am also wondering why Mazda changed all the ABS Sensors (4) on each wheel and the YAW Rate Sensor under rear Console in the Series 2 RX-8??, also PCM is a lot different (mainly due to New Oil Metering) I have not heard of a "reliability" issue with these wheel sensors in Series 1 RX-8's, but, Mazda don't usually change these items unless there are performance or reliability issues??
Sorry, OP but I would do what Jon suggests first...
Old Jul 7, 2010 | 10:54 PM
ASH8's Avatar
Super Moderator
silverkillrx8...Just another thought...Have you driven through/over any Wet Creek beds or Muddy Roads lately, mud and dirt on wheel sensors?...or driven over branches or sticks that may have caught or damaged electrical wiring looms or connector plugs under car??..
Could also be a loose connection at a plug or loom, which could respond to air temperature changes, or a ground?
Old Jul 7, 2010 | 11:05 PM
Jon316G's Avatar
Grasshopper
Yeah... these sensors monitor the wheel's rotation.
The rears use an inductive sensor similar to the e-shaft sensor, but I thought the fronts used a magnetic encoder.
I started thinking about this too as being a potential culprit, but I thought back to a couple years ago when I had a faulty wheel-speed sensor on my '01 F150.
At that time, I didn't have any issues accelerating like the OP mentioned... just a flashing light.
Not saying the 8 can't be different, but that is why I didn't consider it at first.
Figured its best to cover the basic/easy stuff first...
Old Jul 8, 2010 | 08:41 PM
noo i avoid anything in the road period about 3 years ago i hit a possum but this problem didnt happen untill like 6 months ago it used to be often but after my new motor its only like once a week or so last time it happened was last thursday when i was in cruise control on the freeway it just stopped accelerating and the traction light flashed then it went off and the car went back to the speed it was set at si this is why im so stumped because i cleaned the throttle body and reset the pcm it hasnt done it yet but never know when it shall strike again
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
WranglerFan
May 31, 2022 07:51 AM
Randolph Alvarez
May 30, 2016 01:08 AM
nowakm99
Oct 9, 2015 07:10 AM
