Advice on Plugs and Coils.
Old Jul 7, 2010 | 03:11 PM
Leejin's Avatar
Hello everyone. I have a quick question about what I should do with my car. After extensive searching, I've concluded that my plugs and coils need to be replaced. (I just barely went over 31k Miles on original coils/plugs)
One hot day (98 degrees) I drove a few miles to a store. After sitting maybe 5 mins I started it up and it was idling TERRIBLY ERRATIC. When I tried to drive away, the car would barely move. The CEL was blinking so I stopped moving. I tried to give it a little gas and it wouldn't rev higher than 3k. All of a sudden, it balanced out and revved fine. The CEL stopped blinking after a few seconds. I proceeded to drive away and it happened again. So I parked my car and I'm scared to drive it now. I called my Stealership and Coils and Plugs are well over $500. Ridiculous.
My question is this: Is it okay to drive for a few days while I wait for new plugs/coils? I've found plugs on Amazon for about $20 each (Ouch) and can't find coils under $50. (YIKES)
I don't know what I'm trying to accomplish with this topic, I guess just a really great success story that someone could pass along. I can do all the work myself, I just have no idea where I'm going to get an extra $300 from.
Old Jul 7, 2010 | 03:23 PM
invasion08's Avatar
http://www.finishlineperformance.com...cat=338&page=2
The problem with your ignition coils and sparks plugs going bad is your cat converter can go as well. I would order your plugs and coils asap. I am not going to say it is or it is not safe to drive your car. But keep in mind the cat converter is covered under federal emission for 8ys/80k miles.
Old Jul 7, 2010 | 03:27 PM
invasion08's Avatar
Or you can order ignition coils, spark plugs and spark plug wires from Race Roots for $290. That way you will get all your ignition componets at the same time.
http://raceroots.com/index.php/produ...on-bundle.html.
Old Jul 7, 2010 | 04:56 PM
Leejin's Avatar
Cool, thanks a ton man. I'm going to see if anyone locally carries the plugs and change them ASAP. I'll order the Coils and wires as soon as I can. I'm beyond broke.. haha.
Old Jul 7, 2010 | 09:16 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Do I have to have a CEL for a bad cat in order for it to be replaced? I suspect my cat is going bad because of the fuel smell, noise, and slight decrease in performance. No bogging or CEL yet.
Old Jul 8, 2010 | 08:01 AM
invasion08's Avatar
When my cat converter went i had no CEL, just really really bad performance. The car would barely move. Thank God I was near the mazda dealership and got a free rental while they fixed it. Keep in mind that i was still in the original 4yr/50k warranty, that is why i had the free rental.
Old Jul 8, 2010 | 09:01 AM
Huey52's Avatar
Registered Zoom Zoomer
OP, if you can't find the $300 for standard coils/cables then I guess it's a waste of time to recommend the BHR Ignition System, but it sure would likely resolve your issues and provide longevity and reliability.
Old Jul 9, 2010 | 05:12 PM
Leejin's Avatar
Ok, some new info that I've never seen or heard of. I actually found the Spark Plugs at a local parts store ($38 a piece, talked him down to $20.] So, I replaced the plugs, (which looked effing terrible] fired my car up and everything ran amazing! .... for about 24 hours.
I left work for lunch and tried to start my car, and it was doing the mis-firing thing again. So, I totally assume It was the coils all along. But I have to wait for a bit to replace them.
My question is, should I do an ECU reset? I did the 20 brake pump reset, but I'm not sure which RAM that resets. I remember reading something about there being 2 resets.
Could someone else help me with the second reset? If that will fix my problem.
Old Jul 11, 2010 | 12:31 AM
kailua_chaos's Avatar
you could just disconnect your battery for 10 minutes, that should do it...
WranglerFan
May 31, 2022 07:51 AM
tallestmexican
May 1, 2018 07:22 AM
r-enzyme
Oct 1, 2015 01:27 AM
titaneum_grey
Sep 6, 2015 10:21 PM
iwannarun
Sep 6, 2015 01:37 PM
