installed lowering springs... Now i have an issue.
Old Jul 5, 2010 | 12:21 PM
Dream20B's Avatar
Licensed To Smite
Before I start, I searched, tried the listed things, checked all connections are plugged in, nothing I can think of fixes my issue, Tried resetting the ECU as well, that did nothing.
I have a 2008 40th anniversary rx8. I recently installed some tanabe NF210 springs. immediately after first start up, i got an abs and tcs light on, and the cruise control doesn't work either.
I checked the things i unplugged, they were all plugged in. I reset the computer using the full left - full right steering method. I still have the lights on.
Anything else you need to know please let me know. I'll check in on this later.
Oh, and before i forget, car drives fine, but the ABS/TCS/Cruise Control Don't work.
Old Jul 5, 2010 | 06:26 PM
EDZRIDE's Avatar
2005 White GT
Have you checked the fuses?
Old Jul 5, 2010 | 08:25 PM
lilring's Avatar
Finally a MT
you maybe broke a wheel speed sensor
Old Jul 6, 2010 | 08:34 AM
Dream20B's Avatar
Licensed To Smite
this is my guess, any way to check it?
Old Jul 6, 2010 | 08:35 AM
Dream20B's Avatar
Licensed To Smite
I'll take a look.
Old Jul 6, 2010 | 11:29 AM
Dream20B's Avatar
Licensed To Smite
Originally Posted by Dream20B
I'll take a look.
Both The wheel speed sensors and the fuse are in good shape. The only thing i'm concluding is that they don't click when they latch on... maybe i can fix that.
Old Jul 6, 2010 | 04:44 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Its actually Turn Right then Left to reset the steering sensor.
Old Jul 6, 2010 | 04:48 PM
04rx's Avatar
man i got the same proble i made a post and nobody was able to help me either?????
Old Jul 6, 2010 | 05:21 PM
RotaryMachineRx's Avatar
SPOOLN8
Why did you have all of that unplugged to install a set of springs??
Old Jul 6, 2010 | 06:43 PM
04rx's Avatar
when installed my coilovers i did not have any of it unplugged. my guess is dream 20b did not either? i still have not figured mine out just been driving it with lights on?
Old Jul 6, 2010 | 06:46 PM
laythor's Avatar
I zoom therefore I am.
explain exactly how you did the turn the wheel reset. how you described it is backwards. did you have the key to ACC and not to on?
Old Jul 7, 2010 | 04:50 PM
Dream20B's Avatar
Licensed To Smite
Well I tried it both ways, The way i did it backwards was first, then the proper way, neither one worked. I'm assuming i have a bad connection somewhere down the line. I'll be taking it in to the dealer in a few days.
Old Jul 7, 2010 | 04:53 PM
Dream20B's Avatar
Licensed To Smite
I Didn't want to over-stretch the wires when i dropped the a arms and took out the spring assembly.
Old Jul 7, 2010 | 05:12 PM
SPOOLN8
Hmm, well I just installed mine last weekend and had none of these problems. Had a friend help me and held the wheel hub so it didn't fall and pull the ABS line out.
My only thoughts are:
1) Maybe you forgot to unhook a line and dropped the hub
2) Your connections/sensors got dirty and need to be cleaned
3) You are in real bad need of a wheel alignment
Just throwing this out there too... any adjustments to the suspension usually mean you should go get a wheel alignment too for safe measure and even tire wear.
Old Jul 7, 2010 | 07:42 PM
Dream20B's Avatar
Licensed To Smite
I know i'm gonna need the alignment, but money is tight atm. probably not my best idea to do springs right now but oh well.
I'll check on #2.
#1 would be very unlikely but possible, I'll look into it too.
just1jack
Sep 9, 2015 04:45 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
dbarber
Jul 25, 2015 01:34 PM
