car died, security light flashing rapidly, wont start. any ideas>??
Old Jul 4, 2010 | 07:04 AM
kdoiron08's Avatar
so i was driving and my car died. it doesnt try to turn over, all i hear is a click. also my red key light is flashing rapidly for about a minute after attempting to start it, slows down a little for maybe another minute, then goes back to flashing normal. My keyless remote hasnt worked in a few months now either, so i was thinking maybe my car thinks its stolen and the security system is causing this, LOL.. is that possible?? thanks
Old Jul 4, 2010 | 11:23 AM
EDZRIDE's Avatar
2005 White GT
Start with the basics. Check the battery and connections, clean an charge as required. Also check the tension on the alternator belt and check the charging system once you get it running.
Old Jul 4, 2010 | 11:39 AM
zoom44's Avatar
the module that controls the security features and authorizes the key is on the fritz its in/behind the glove compartment. your going to need to go to the dealer for them to fix it.
Old Jul 4, 2010 | 11:39 PM
kdoiron08's Avatar
having it towed tomorrow to the dealer tomoorow. thanks
Old Jul 7, 2010 | 02:38 AM
kdoiron08's Avatar
dealer said they need more time, cant comminicate with the computor. WTF
Old Jul 7, 2010 | 10:45 AM
zoom44's Avatar
can bus module failure can sometimes leave the bus "occupied"
Old Jun 1, 2011 | 04:09 PM
Jordan0101's Avatar
Hate to revive old threads, but I'm having this exact same issue and can't seem to find any other advice. For the OP, did you get the problem fixed? What happened and what did it take?
Old Mar 4, 2012 | 04:10 PM
Chino_rx3's Avatar
Gulf Coast Rotaries
same issue ..My car started when I got it car was very dirty So I started cleaning and bought m a red top battery bhr ignition and before I install anything I try to turn on car nd nothing at all,, lights flashes fast I didnt do anything diferent or remove anything I tried a test light with main fuse the 120 and looks like theirs power, My radio dont work it did before , is weird Im going to hate taking it to the dealer, any suggestions,
Old May 19, 2012 | 06:42 PM
DomesticRx8's Avatar
same problem today. This is the most sensitive car i ve ever owned!
Old May 17, 2015 | 05:41 PM
lhublard's Avatar
How much did the dealer charge to fix this issue with the security light flashing and car not starting
Old May 17, 2015 | 06:27 PM
There is a very high chance that the chip on ur key went dead. I seen it
takes 5 minutes for dealer to program a new one, u just have to get the right new blank chip(make that 2), take the one out from ur old key, install new, take car to dealer (or whoever can program PATS like me) and 5 minutes later u should be good.
Old Mar 30, 2016 | 02:00 PM
user 588432336's Avatar
UK Having the same issue, although slightly different..
Having a similar issue:
Was cruising along today 25mph, 3000 revs, for no apparent reason all dash lights came on and odometer and speedo dropped to zero although engine was still running, was going in a straight line road was dry.
Switched off and got the rapidly flashing security light, engine refused to turn over. After 10 minutes re-tried starting and it fired up, although CEL and DSC/TCS lights are on.
I have an OBD error checker which states codes UO121, UO155, UO167.
similar reported issues are:
https://www.rx8club.com/series-i-tro...flashs-214331/
https://www.rx8club.com/series-i-tro...how-up-167494/
I have checked all fuses that you can visually check and all are fine, no work has been done on the vehicle recently and the only reason i've gone in the engine bay is to check the oil.
In the last 3 days since then it sometimes starts first time without issues, sometimes i get the security light which takes 5 mins to switch off (after which it starts fine)
Any thoughts?
possibly an issue with the ignition receiver module?
any one seen this before and fixed?
Old Oct 9, 2016 | 12:09 PM
zooomrx8's Avatar
how to reset security light flashing
All you have to do to reset the security light after a dead or changed battery is turn the key to the ON position (do not start) and tap on the brake pedal about 20 times, or until the oil pressure gauge moves up to about ½way. This worked on my 04 the first time I tried it.
Skyl3r
Dec 2, 2019 04:51 PM
marc2820
Jul 26, 2015 10:47 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
Jmanie9515
Jul 20, 2015 07:29 PM
