AP pulley install - stripped bolts
Old Jul 3, 2010 | 11:31 PM
maskedferret's Avatar
Oooh, shiny!
I stripped two of the bolts as I was trying to torque them down. I don't know how I'm going to get these out in such a confined space. Does anyone have any suggestions on how to get these out?
Everything seems to run fine; the stripped bolts were at least tightened down somewhat, but I would rather replace them for the sake of knowing they're torqued down properly. That brings up another question; has anyone ever ordered replacement bolts? I assume I should just call Agency Power?
Old Jul 3, 2010 | 11:38 PM
Brettus's Avatar
Boosted Kiwi
so when you try and wind them out they just rotate and don't come out ?
Old Jul 3, 2010 | 11:43 PM
Oooh, shiny!
Oh, sorry... "stripped" as in mangled the hex socket of the two bolts; the threads themselves should be fine. However I cannot easily twist them out because they're already kinda tightened on, and a hex#5 bit pretty much just spins around in the socket of the bolts now.
Old Jul 3, 2010 | 11:49 PM
Jon316G's Avatar
Grasshopper
Find an SAE socket that is a little smaller and tap the socket onto the bolt head with a hammer.
Yes this will further damage the bolt head, but who cares, you're replacing it.
Old Jul 3, 2010 | 11:55 PM
Oooh, shiny!
To be clear, you're suggesting to use a socket as opposed to a bit, yes? Otherwise, i'd think to use a slightly larger bit.
I guess more stuff is gonna have to come out (battery, airbox tray, intake) to get swinging room for a hammer.
Old Jul 3, 2010 | 11:58 PM
Jon316G's Avatar
Grasshopper
Yes... no reason to drill it out if you can find a way to grip the bolt head.
A slightly smaller socket tapped onto the head should give you enough grip to turn the bolt out.
Old Jul 4, 2010 | 01:33 AM
Brettus's Avatar
Boosted Kiwi
/\ They are allen head cap screws on the AP pulley
But jons idea can work for a capscrew as well - get the next size up allen key and grind it down to be a tap fit into the holes .....
Old Jul 4, 2010 | 01:38 AM
Jon316G's Avatar
Grasshopper
Damn... shows you how long its been since I've installed an AP pulley!
Thanks for correcting me Brettus.
Old Jul 4, 2010 | 08:43 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Generally, I will usually find a pair of vise-grips that will get in there and use those.
Isn't the torque number on those bolts pretty light? My UR's are something like 8ft-lbs on the eccentric shaft and water pump.
Old Jul 4, 2010 | 12:35 PM
Oooh, shiny!
Staticlag had a bit of a DIY out there for the install; he quoted 10-12 ft.-lbs.
https://www.rx8club.com/showpost.php...9&postcount=34
Old Jul 4, 2010 | 01:03 PM
Another thing that often works is to tap a Torx head into the hole.......They will often grab quite well in a stripped out Allen head bolt
Old Jul 6, 2010 | 01:46 PM
nuke0907's Avatar
Never Blend In
what the heck did you use to tighten them? i found it helpful to use the ball-end hex wrenches to get to them at a better angle.
Old Jul 6, 2010 | 01:49 PM
Oooh, shiny!
Originally Posted by nuke0907
what the heck dod you use to tighten them? i found it helpful to use the ball-end hex wrenches to get to them at a better angle.
Once they are hand tight with a hex#5 bit in a socket-bit adapter, I find there is enough room to then use your typical torque wrench to tighten them to spec.
Old Jul 6, 2010 | 03:28 PM
Mazurfer's Avatar
^.................make sure you check them again after a couple of days!
Old Jul 6, 2010 | 03:31 PM
Oooh, shiny!
Absolutely. I've been watching the pulley motion before and after driving sessions. So far it seems things are good. I'll check the actual bolts tonight or tomorrow. Regardless, I am on the hunt for a replacement set of bolts.
Old Jul 6, 2010 | 04:31 PM
VashGS's Avatar
Zoom Zoom Addict
Go to sears and get stripped bolt tool. It fits over the top they sell it as a set.
Put a shot of PB blaster before trying to stripped nut tool. In future use a little silver locktite, I apply and then wipe down with paper towel to leave only a little bit.
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RXFEVER
Sep 11, 2016 02:51 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
