8 wont start
Old Jul 2, 2010 | 03:31 PM
hmdmvp's Avatar
8 wont start
ok so i dropped an engine in my 04 mazda rx8. automatic. i hooked everything up and now when i try to start it, it wont. when i do, the engine turns and and the air pump gets goin, but thats it. Im a mechanic but i am not familiar with the rotaries, any suggestions? i know its gotta be spark or fuel maybe so thats what ill check first. thanks
Old Jul 3, 2010 | 03:54 PM
hmdmvp's Avatar
anyone? does anyone know where i can find a diagram?
Old Jul 3, 2010 | 04:02 PM
Jon316G's Avatar
Grasshopper
What kind of diagram are you looking for?
When I swapped an engine it took a long time to get it started.
It sounded (and smelt) like a flooded engine so we treated it as such.
I was told by other members later on that its not uncommon for our engine to have a difficult time starting the first time.
Old Jul 3, 2010 | 05:48 PM
hmdmvp's Avatar
well i went out and took the plugs out, they were a bit dark but not soaked i cleaned them with carb. cleaner and put them back in. i left one out, i connected that one and held it up to ground and cranked the engine and got a jump so there IS spark. maybe it might be a gas problem? there is pressure in the lines, i disconnected one and got sprayed. pump also seems to work. so i am guessing the injectors might not be firing. does anyone know any method of testing to see if there are pulsations? im gonna try to get a noid light but im just asking. a diagram of the injector circuit would be helpful.
thanks Jon316G
Old Jul 3, 2010 | 05:55 PM
Jon316G's Avatar
Grasshopper
The Service Manual shows how to test the injectors:
http://isomerica.net/~fluffy/Ren/RX8%20FSM/
Its in the 'Engine Details' section starting on page 143
I have my doubts on the injector (especially if you have pressure), but try it out if you like!
Old Jul 6, 2010 | 03:34 PM
hmdmvp's Avatar
well yea but you could have pressure and not have the injectors firing, ill take a look at that link tho thanks
Old Jul 9, 2010 | 01:10 AM
hmdmvp's Avatar
i got a good set of noid lights from harvard freight, no signal, my next step is to get a diagram and try to figure that out. maybe a common ground? idk. if anyone has any other ideas or thinks that i am not in the right path please let me know since i am not too familiar with these engines. thanks
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
poppinparker
Aug 10, 2015 09:20 AM
T_Mags
Jul 24, 2015 11:29 AM
