mazda speed strut bar question
Old Jun 18, 2010 | 08:25 PM
living the dream's Avatar
just purchased a brandy new cf front strut bar
heres how it went
took the old strut bar off
put the new one on but the main bracket were the bolts go through for the shock to bolt into the strut bar the hole were a little off soo i lossened the lock nut allen head on the main bar on both ends put it into place and torqued the main bolts down then when they were in place i tightened up the lock nut allen head bolts for the main bar...is that ok i loosened those two bolts or does mazda ship them out in spec from were they should be
just curious
Attached Thumbnails mazda speed strut bar question-strut_tower_bar_front_lg.jpg
Old Jun 18, 2010 | 08:33 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You should be just fine! Don't worry about it, I had to do the same thing(I think?) a few years ago when putting mine in.
Old Jun 18, 2010 | 09:05 PM
m1r4g3's Avatar
Kinohashi
yes
Old Jun 18, 2010 | 09:08 PM
ganseg's Avatar
Nature vs. Nurture
Do you have enough room to put a rebound adjuster on the dampers? My stock strut bar is in the way.
Old Jun 19, 2010 | 08:42 AM
Thats the reason why those bolts are there.
*sigh ... where is the common sense these days ... *
Old Jun 19, 2010 | 12:48 PM
ganseg's Avatar
Nature vs. Nurture
You might be missing my question. I have KW3s with rebound adjusters. The stock strut bars shroud that area so I can't get the adjuster handle on the adjuster. I can barely turn them with a needle nose pliers. If the MS tie bar has more open area directly above the adjuster, it will be easy to adjust the dampers. sigh
Old Jun 19, 2010 | 05:14 PM
chiefmg's Avatar
Out there...
There are differing levels of mechanical aptitude. What might be apparent to you or I isn't so obvious to someone else. He had something he wasn't sure about and had enough sense to ask the question of those with more knowledge.
We all have to start somewhere...
Old Jun 19, 2010 | 05:16 PM
chiefmg's Avatar
Out there...
Don't quote me on this one, but from what I have read and seen of the MS bar, there is enough room to get to an adjuster. It mounts up higher than the stock bar.
Modified Dave
Sep 19, 2015 08:58 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Jazzmeson
Jul 31, 2015 01:48 AM
nnsoch1776
Jul 22, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
