Installing rear under deflector(OEM Aero kit)
Old Jun 14, 2010 | 09:43 AM
Mazda_RX804's Avatar
Hate Scrape 8
The instructions say you have to remove the rear bumper, is there a way in doing this without removing the bumper?
any tips?
Old Jun 16, 2010 | 04:56 PM
gbsn64's Avatar
Yee, remove the little plastic tab (cut it or sand it down) and the clip screw on the rear flares (use a flathead screwdriver to lift the metal clip)
So it ends up being held by the wheel well screw and the 3m tape, which is perfectly fine. You just need to give it some time (1 day or so) so the tape reeeaaally sticks on, as with any tape... (no car wash, no going over water filled pot holes and splashing water all over the road... stuff like that)
Old Jun 17, 2010 | 02:32 AM
Hate Scrape 8
cant u still make the slot? u can reach in the bottom of the car to stick in the aligator clip
Old Jun 17, 2010 | 06:04 PM
gbsn64's Avatar
Then im pretty sure you can drill the other hole too. I dont know how much clearance you have by going that route to drill, if you have enough, then go for it.
jay_tibo
22
Sep 13, 2016 08:10 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Jazzmeson
Jul 21, 2015 02:54 PM
AussieGray
Jul 16, 2015 03:58 AM
