Cute plugs+coils.
Old Jun 14, 2010 | 12:07 AM
tubingchamp's Avatar
What mawd bug?
Cute plugs+coils.
Check this out.
Did a spark plug + wire swap (and unintended coil swap (thanks Dannobre for the help, coils and Charles for the plugs+wires)) today, and found some interesting results..
I had two pretty decently bad plugs, only took a picture of one of them, and same with the coils connected to those plugs. Took my car to the dealership I guess two weeks ago, said I had loss of power, asked them to check the plugs. Well, I guess they didn't.
My car's been running like this for a little while, no idea it was this bad.
What's wrong with that picture?!?!
Also, during the drive home, my car was SUPER quiet, and felt like there was an ***-ton of back pressure. The higher rpm I went, the quieter it got. I did a test, and in 2nd gear I redlined it. Around 7K RPM, it hesitated, then POP! I saw a cloud of smoke and a small object spiraling out of my tailpipe.
Guessing it was the cat. Anyone ever had this happen? I figured a blown cat wouldn't actually come out of the exhaust tip.. I can't get under the car to check it out ATM, but I checked to see if my cat was glowing after the latest drive. Nothing, it runs like a FREAKING CHAMP now though. Thanks again Charles and double thanks to Dannobre
Old Jun 14, 2010 | 08:42 AM
What mawd bug?
Bah!
No one else has blown their CAT out of their tailpipe?
Old Jun 14, 2010 | 08:56 AM
racerboy59's Avatar
sounds like your cats insides broke up and its not uncommon for bits to get stuck in the muffler and rattle about. but yours managed to find its way out of the car. i would get your cat changed and also inspect the cat back for loose parts.
Old Jun 14, 2010 | 09:24 AM
scremn8's Avatar
the more things change
Originally Posted by tubingchamp
Bah!
i blew out an rp super cat on a dyno run.
came out as little specks.
Old Jun 14, 2010 | 10:59 AM
What mawd bug?
I really hate emissions laws.
I'd rather have a straight pipe.
Old Jun 17, 2010 | 10:35 AM
I'd rather die from lung cancer.
Old Jun 17, 2010 | 10:39 AM
What mawd bug?
Originally Posted by TeamRX8
<3..
Hey, I don't smoke, so I figure I need to get lung cancer somehow, right?
Everyones doing it these days.
Old Jun 17, 2010 | 11:14 AM
8upbad's Avatar
Jared
Wow I need to check my coils! Of course, if they are bad they'll be like 4th in the line of other **** I need done NOW.
Old Jun 17, 2010 | 07:51 PM
I was amazed that the thing ran at all.....despite the fact that both coils on the rear rotor were corroded through the metal in the wire socket...and one plug was missing the end...it was still firing.....sorta anyway..the plugs were surprisingly very normal looking on the electrode ends.
Typical dealer though...complain under warranty and they won't do anything unless there beloved computer tells them there is a problem
njItalianboy
RX-8 Multimedia/Photo Gallery
55
Oct 9, 2005 11:29 AM
04MazdaRX8
39
Jul 5, 2004 11:00 PM
feefee
Europe Forum
11
Sep 12, 2003 07:53 AM
