Testing ignition coils?
Old Jun 9, 2010 | 03:42 PM
Tex8's Avatar
is there any way of testing our coils to see if they have failed? i know that you can use an ohm meter to test some of the older ones, but does this apply with ours?
Old Jun 9, 2010 | 09:34 PM
Jon316G's Avatar
Grasshopper
With a meter you are testing the coil windings for shorts.
Can you test for this... yes.
But if a coil is dieing and producing weak spark, you'll likely still read resistance on the coil.
Now if the igniter is bad... there is nothing (that I can easily think of) to bench test that, and unfortunately, its a likely component to fail.
Best way is to use a timing light to gauge against the other coils and see if one is weaker or more inconsistent than the others
Old Jun 10, 2010 | 08:44 PM
Or save yourself an hour of pissing around and just buy a new set ( $120 or so )
Old Jun 10, 2010 | 09:21 PM
imop45's Avatar
dannobre: so you get paid $120 an hour? :p
Old Jun 11, 2010 | 12:23 AM
That wasn't the point
05TR1CH
Apr 18, 2023 04:56 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
talonhart2
Aug 26, 2015 04:14 PM
steve11711
Aug 22, 2015 11:11 AM
madrotor
Jul 26, 2015 12:06 PM
