Knightsports Supercharger Kit
Rating: Thread Rating: 2 votes, 3.00 average.
Old May 31, 2010 | 08:12 PM
tofu_box's Avatar
Just paid in full for this supercharger kit, should arrive in a few days
I am just after a reliable everyday street setup.
I'll upload photos when i get the parts.
Ok Updates!
Parts are being flown in from across the globe!
Final List of Mods going in:
Knightsport Supercharger Kit
BHR Radiator
BHR Walbro Fuel Pump
Mazmart Oil Pressure Mod
5ply Silicon Radiator Hoses
Greddy Oil Pan
Carboninmotion 2nd Oil Cooler
Knightsport & Feed Gauge Pod
Prosport Gauges : Wideband O2, Boost, Oil Pressure + Temp, Water Temp
Turbosmart: Kompact Dual Port BOV, Converted into full bypass valve using included Backing Plate, Changed Spring with soft springs.
DRIFT Oil Catch Can
ECU Choice, Flash MAF Tune using Protuner, If this fails we are going Adaptronics ECU Map Tune
Minor Details:
Flush/Clean of Supercharger Kit
New Oil Filter + Traction Oil for Supercharger Unit
Decarb of Engine
Coolant Flush
Oil Flush (still going to use Penrite Semi-Sythentic 5w-40)
Lines rearranged
Clean up of Promaz Ignition Kit Harness
Mods Coming OUT:
Agency Power Underdriven Pulley (too small)
Racing Beat Intake+Duct (obvious reasons)
Attached Thumbnails Knightsports Supercharger Kit-se3pb.jpeg   Knightsports Supercharger Kit-dsc00523.jpg   Knightsports Supercharger Kit-dsc00524.jpg
Old May 31, 2010 | 08:16 PM
tofu_box's Avatar
First Mock Up Install
Specific Page 8
Attached Thumbnails Knightsports Supercharger Kit-img_0056.jpg   Knightsports Supercharger Kit-img_0057.jpg   Knightsports Supercharger Kit-img_0058.jpg   Knightsports Supercharger Kit-img_0062.jpg   Knightsports Supercharger Kit-img_0063.jpg
Old May 31, 2010 | 08:17 PM
tofu_box's Avatar
final installation progress picture
and on the dyno
Sorry about that loud fan!
http://www.youtube.com/watch?v=4jQLCmjwDPA
Attached Thumbnails Knightsports Supercharger Kit-gauges.jpg   Knightsports Supercharger Kit-sc-final-install.jpg   Knightsports Supercharger Kit-sc-dyno.jpg
Old May 31, 2010 | 08:20 PM
tofu_box's Avatar
Reserved for Pic3
Old May 31, 2010 | 08:27 PM
this should be interesting...
Old May 31, 2010 | 08:28 PM
mscamp02's Avatar
Blue Bullet?
very I cant wait to see something
Old May 31, 2010 | 09:14 PM
Brettus's Avatar
Boosted Kiwi
Can't keep up - Dynotune -Turbo -SC
Is this the FINAL solution ?
Old May 31, 2010 | 09:45 PM
tofu_box's Avatar
hahah Brettus, yes this is the final solution.
Dynotune is happening at the moment for my extractor/hi flow cat/ exhaust combo
We want to tune and work with my car N/A before going FI
I actually bought the Greddy Turbocharger Kit, but then the seller retracted and refunded me the money.
Then it was decision between supercharger then turbo.
In the End it was the supercharger, which is on its way from Japan as we speak.
:D
Old May 31, 2010 | 09:52 PM
total price?
what are you using for engine managment?
chino0314's Avatar
hmmm..
Old May 31, 2010 | 10:01 PM
OchoShinka's Avatar
I haven't heard of the Knightsport kit. So I am about to research it :-D
I think S/C can make up the power that the car really needs on low end. I'm interested in following your future posts to hear about how things go.
Keep us all informed on how well you like it.
Old May 31, 2010 | 10:15 PM
tofu_box's Avatar
Originally Posted by Jedi54
total price?
i purchased it for 5k Australian, this is a 2nd hand with about 9000 kms on it, straight from Japan from a wrecked rear ended rx8. The seller owns a wrecking yard in Japan and is selling wrecked parts directly here in Australia.
It comes with a ECU that is pretuned i think it might be a Emanage Ultimate, not sure.
I also have a Microtech LT10 - Interceptor X
At the moment im running Protuner for my car
We will experiment with these ECU, most likely staying with flash ecu tuning.
hmmm..
mmmmmmm?
It is a centrifugal supercharger, so it will be less power then twin screw in low end
however the powercurve will be very linear, i just cant find that dyno graph from knightsport.
It was said that this kit can achieve up to 290psi/hp.
I wont be going that high due to two things
- Auto 4 port :D
- reliable street tune
at the moment my car is at 130hp rear wheels
My aim is around 200 hp rear wheels for a 4 port
Will that be enough for the future? probably not
But it is more then enough for a daily street car,
Less hp = less wear = less expenses
I know with a greddy turbo i can expect to see higher numbers,
But for my application i really think 200-214 hp is enough.
so supercharger will prob be ran at around 5-7 PSI
On a side note my mechanic is friends with the official Knight Sports Distributor here in Australia
At the moment he is running 4 port 5speed JDM model with a mild port on engine, running Microtech ECU, knightsport supercharger kit
He is seeing roughly 275-280 hp at rear wheels.
They are in the process of building a new 6 port engine by Xtreme Rotories, that contains the "lot" (seals, doweling, more?) dont know. That was all that i was told
It will be interesting to see how it comes out, and on the side note we have a rx8 track day national here in Australia,
That RX8 described above may see live track experiments with the new engine if it is completed in time.
I shall post updates as continues
P.S
I just purchased the knight sports gauge pod from Japanparts
http://blog.gtroc.com/dino/KS-RX8-08.jpg Its the one to the left side of your cluster.
This will be together with a FEED gauge pod setup. opposite of the lotek one for RHD
Im using prosports gauge pods
at the moment the ones ordered are
-EGT
-Wideband O2
-Boost
-Oil Temp
- For the last one im throwing up between Water Temp, Oil Pressure, Vacuum
Which one you guys reckon?
Regards
Jason
Old May 31, 2010 | 10:27 PM
OchoShinka's Avatar
My last car, a Mustang, was at 220rwhp. It was more than enough power to make trouble in the streets on a daily driver. When I got my 8 I wished to have similar HP output that my Mustang had, it would make the 8 a monster for a daily driver(these cars are just phenominal when it comes to handling, I can't imagine driving anything else).
I've looked at the procharger s/c but $8K is just too much money for the setup in my opinion.
I am really interested to see how your setup works out for you. Whats the ETA for your kit to arrive?
Old May 31, 2010 | 10:33 PM
tofu_box's Avatar
3 days
Why dont you look at Petite Supercharger?
If i was in the US, id get the Petite in a heartbeat.
Old May 31, 2010 | 10:42 PM
OchoShinka's Avatar
I am torn between the Petite kit and the Greddy kit. I think I rather add a turbo to the 8, personally. You never know what can happen though :-)
Old May 31, 2010 | 10:44 PM
tofu_box's Avatar
Personal Preference.
I reckon turbo is pretty cool though :P
Old May 31, 2010 | 11:21 PM
I saw the Knight Sports kit in person and the action
The kit is very well designed ... one thing I dont understand is the intake filter location, Its right next to the intercooler ... I mean it comes with a duct to direct cold air from the front. but if u're stuck in traffic and right next to the intercooler + Radiator under ...
The owner of the kit said he had that concern too but, so far no problems. and Knight Sports people came all the way to install and tune it for him.
For Regular Street driving, its very linear. and the power is there whenever you need it.
I was thinking about buying it too. But I got other stuff to deal with right now so I will get it later.
Old Jun 1, 2010 | 12:01 AM
tofu_box's Avatar
In regards to that duct, im gonna try fabricate my revi duct to work with the kit, if not i'll use the ***** design :P
Old Jun 1, 2010 | 01:47 AM
shadycrew31's Avatar
WENTGERMAN
hmmm I'd like to know the actual cost from knight sports with their tuner flyout special...
There site is fubar in English so yea.
Old Jun 1, 2010 | 02:08 AM
lzhmax's Avatar
Rotryyyyyy
Are you in Adelaide?? I hope Knightsports do make s/c kits for s2. Do u mind if i ask you how much is it? I really preffer s/c than turbo.
Old Jun 1, 2010 | 02:10 AM
lzhmax's Avatar
Rotryyyyyy
BYW, why dont u look at Hymee? It's pretty good as well.
Old Jun 1, 2010 | 03:47 AM
tiltmode43's Avatar
OMGITM!
Looking forward to updates
Old Jun 1, 2010 | 05:54 AM
tofu_box's Avatar
Hymee is still in production and a 12k+ price tag.
Old Jun 1, 2010 | 10:51 AM
WENTGERMAN
thanks to google translate I have info...
288 whp
$8700 (without tuning)
$9600 (with tuning)
Id rather get a procharger.
Old Jun 1, 2010 | 05:44 PM
tofu_box's Avatar
top stuff, go get pro charger.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
